8.8 questions - JeepForum.com
post #1 of 10 Old 02-23-2010, 07:57 PM Thread Starter
jeepwyj94
8.8 questions
i have a 8.8 in my jeep and it has the lsd . i was wondering if i could put an aussie locker in it, or if i would have to change stuff?
jeepwyj94 is offline
post #2 of 10 Old 02-23-2010, 08:04 PM
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
your gonna need to get an open carrier for the aussie to fit in
87 YJ, 07 JK 5.3 Vortec
Firefighters Jeep Club
p_Club
JJ-4 is offline
post #3 of 10 Old 02-23-2010, 08:14 PM
JIBTEXHNKA
1987 YJ Wrangler
Cheapest solution would probably just be to get a full-carrier locker like a Detroit. Whatever you do, short of replacing the entire axle, you're going to have to reset the gears so might as well get the stronger locker while you're at it.
87 YJ, rebuilt 4.0, dana 30 w/ aussie locker, 8.8 rear end with lsd, 34x10.50 bias swampers, warn 8274, some fancy stuff, some crappy stuff ROLLED, REPAIRS IN PROGRESS
JIBTEXHNKA is offline
post #4 of 10 Old 02-23-2010, 08:30 PM
CreepyCrawler95
detroit all the way
CreepyCrawler95 is offline
post #5 of 10 Old 02-23-2010, 09:37 PM
burnout189
x3 on detroit
BARNHART'S AUTO REPAIR
burnout189 is offline
post #6 of 10 Old 02-23-2010, 11:02 PM
bigsquat
sometimes you can get used carriers at a diff shop for around $40. if $ isnt an issue then i agree with the detroit. ive heard aussies are a pain to put in a 8.8 anyway.
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD:
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
bigsquat is offline
post #7 of 10 Old 02-24-2010, 06:15 AM Thread Starter
jeepwyj94
thanks for the input
post #8 of 10 Old 02-24-2010, 06:55 AM
dodger889
Some where iI have read about putting better springs and clutches in an 8.8 lsd to make them work better. That might ne a cheaper solution for you. The article I read was on a mustang site. So this might give you something to think about and search out. I would do the search myself but right now the connection I have is just able to get on here.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #9 of 10 Old 02-24-2010, 08:03 AM
bigsquat
Help Build a Budget 8.8 - Mustang Forums at StangNet
http://www.jeepforum.com/forum/f9/8-...nstall-832811/
8.8 lsd Clutch pack install - Ford Mustang Forums
bigsquat is offline
post #10 of 10 Old 02-24-2010, 11:20 AM Thread Starter
jeepwyj94
thanks guys ill look into it, chances are ill end up with a detroit
CB for the JK...got some Questions. BWR JK Wrangler Technical Forum 16 03-04-2008 08:43 PM
a few questions Fr87hN TJ Wrangler Technical Forum 2 03-19-2007 01:15 PM
New/Questions? 91YJ4X4 YJ Wrangler Technical Forum 4 03-18-2007 06:38 PM
More 8.8 questions... Jeepinjoshwa YJ Wrangler Technical Forum 6 06-22-2006 09:26 PM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 04:34 PM
