8.8 question - JeepForum.com
post #1 of 14 Old 08-26-2014, 01:54 PM Thread Starter
Fozzybear42
8.8 question
Found my 8.8 this weekend so I'm starting to gather the odds and ends for my swap and I can't find the answer to this question.
Are there any pros or cons of using the spicer 1310 flange VS using the ford flange and a 1310 to 1330 conversion u joint?
Also, I have read a few places that the flange out of a grand marquise is the 1310 flange. Using Napa, the part number for the rear driveshaft @ rear diff u joint on the YJ is the same as the part number on the grand marquise. Is this adequate proof? Can anyone 100% confirm that this flange will take a 1310 u joint? Does anyone know specifically what years for the grand marquise?
Fozzybear42 is offline
post #2 of 14 Old 08-26-2014, 01:59 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Get the one that your drive shaft has, likely 1310 on a normal YJ. That also means that your rear and front u-joints are the same, nothing special needed for trail spares.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 14 Old 08-26-2014, 02:23 PM Thread Starter
Fozzybear42
That's an excellent point, didn't think of that at all.
So 1310 flange it is. Can anyone verify that the Grand Marquise has the 1310 flange or am i stuck buying the spicer one?
post #4 of 14 Old 08-26-2014, 03:33 PM
Jeepsr4me
Slick way to tell if the part you want is interchangeable is to go to Orielys and put in for your U joint. Then click on the joint.
It will list all other cars and trucks it fits. And it will be a lot of them.. Then just pick the ones that have a 8.8 and bam...
I been doing this for years... Be surprised what other vehicles stuff fits./.
Jeepsr4me is offline
post #5 of 14 Old 08-26-2014, 04:09 PM Thread Starter
Fozzybear42
Well the plot thickens..... When I pull up the u joint for my jeep it is 1.063 diameter and 3.217 length and it shows compatibility with 92-94 LS or GS Grand Marquis. However when I start with a 92, 93, or 94 Grand Marquis and look up the u joint it brings up 3.622 length and 3.217 length. The 3.217 shows compatibility with YJs, the 3.622 doesn't. I'm so confused......
post #6 of 14 Old 08-26-2014, 04:25 PM
JeeperDon
JeeperDon's Avatar
The 3.21" wide one is a 1330, 3.06 or so wide is a 1310, same caps. My 8.8 came with a 1330 yoke plate and I used a conversion plate on day one. I later updated the driveshaft (Tom Wood) and got that end as 1330 so I didn't need the conversion u-joint any longer. Unlike what I suggested above, I don't have the same u-joint front and rear, but I do have standard u-joints all over now.
Web Admin for
post #7 of 14 Old 08-26-2014, 06:29 PM Thread Starter
Fozzybear42
I got a definitive answer from Napa. The grand marquis has a police package available that came with the bigger joints. The base model has 1310s and the police package has 1330s. If i can find a base model at the JY, the flange should work.
post #8 of 14 Old 08-27-2014, 05:33 AM
StanF
Early Explorers with rear drum brakes also have the 1310 flange...91-95
StanF is offline
post #9 of 14 Old 08-27-2014, 05:47 AM
grandboost98
Didnt rangers with 8.8s come with 1310 flanges?
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #10 of 14 Old 08-27-2014, 08:18 AM
Jeepsr4me
When you click on the u joint from the store, it will have a tab that list all the vehicles it fits. Then click on the MODEL of car or truck you think will have the 8.8 rear. Since it will have the right U joint and the flange. Since 2053 FORDS have the same U joint rear, there will be a LOT of vehicles to choose from
This part also fits:
American Motors189 vehicles
Buick77 vehicles
Chevrolet2298 vehicles
Chrysler10 vehicles
Dodge435 vehicles
Ford2053 vehicles
GMC2058 vehicles
Honda21 vehicles
Infiniti6 vehicles
Isuzu109 vehicles
Jaguar41 vehicles
Jeep820 vehicles
Land Rover20 vehicles
Lincoln135 vehicles
Mazda87 vehicles
Mercedes-Benz11 vehicles
Mercury420 vehicles
Mitsubishi10 vehicles
Nissan265 vehicles
Oldsmobile137 vehicles
Plymouth9 vehicles
Pontiac172 vehicles
Suzuki9 vehicles
Toyota128 vehicles
Volvo
post #11 of 14 Old 08-27-2014, 08:42 AM Thread Starter
Fozzybear42
Nice, that'll be much easier to find. Thanks
post #12 of 14 Old 08-27-2014, 09:17 AM
Jeepsr4me
If you look on the site below under compatibility, you will see that joint fits more than that set year..
http://www.oreillyauto.com/site/c/de...7127&ppt=C0362
post #13 of 14 Old 08-29-2014, 08:20 PM
yellowfrog
1987 YJ Wrangler
I have the 8.8 in my jeep. I'm not home right now so I can't give you part numbers. The u-joint I use is off set ( two different sizes) when I get home I'll find the part numbers and post them. 👍
yellowfrog is offline
post #14 of 14 Old 08-29-2014, 08:32 PM
yellowfrog
1987 YJ Wrangler
[QUOTE="yellowfrog"]I have the 8.8 in my jeep. I'm not home right now so I can't give you part numbers. The u-joint I use is off set ( two different sizes) when I get home I'll find the part numbers and post them. Sorry I was reading this on my phone and missed some of the info. I used the 1330. But it would be nice is all my ujoint were the same for trail repairs ( less to carry with me)
