8.8 Parking Brake Shoe - Problem - JeepForum.com
post #1 of 8 Old 10-10-2010, 11:37 AM Thread Starter
linusb
While working on my 8.8, I discovered that one of the shoes for the parking brake is a bit dislodged. I was turning the shaft from the other side with a lug stud not all the way seated from behind and am not sure if it knocked something lose. I know nothing about drum brakes and am looking for advice to get this back into place.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #2 of 8 Old 10-10-2010, 12:05 PM
provinT13
pics from the inside or looking down. Looks like something maybe hitting it.
2 Hands Working Do More Than 1000 Hands Praying
provinT13 is offline
post #3 of 8 Old 10-10-2010, 12:17 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
With the axle shaft out of the way, this is what it *should* look like:
In your case - I *think* what happened was that the loose lug contacted this piece & dislodged it while you were turning the shaft.
Joe Dillard is offline
post #4 of 8 Old 10-10-2010, 12:17 PM Thread Starter
linusb
The back of the lug stud was hitting it...one was broken and I replaced it with a new one. Nothing is hitting it now, I'm just not sure how to get it back into place. I can take more pics.
linusb is offline
post #5 of 8 Old 10-10-2010, 12:21 PM Thread Starter
linusb
I bet you are exactly right. What do I do to fix? Do I need to remove axle shaft? What is the way to remove the shaft?
linusb is offline
post #6 of 8 Old 10-10-2010, 12:26 PM
Joe Dillard
Since the axle shaft flange makes it difficult to get at the backing plate & attachment parts, you *might* have to pull the shaft to get to the loose/dislodged part.
If so, you'll need to pull the diff cover, remove the main cross shaft retaining pin, then slide the main pin out, then spin the c-clip so you can pull it out with some needle nose plyers. Once the c-clip is pulled, you can gently slide the axle shaft out enough to get to the brake parts.
Be extra carefull NOT to damage the axle shaft seal.
post #7 of 8 Old 10-10-2010, 12:27 PM
Joe Dillard
If you'd like, I can PM you my cell phone number......
post #8 of 8 Old 10-10-2010, 12:30 PM Thread Starter
linusb
I think I got it taken care of...just tapped it back into place.
Thanks for the tips on removing axle! Hopefully all is good...guess I won't know until I try to engage and disengage the parking brake! ...whenever that might be since none of it is yet hooked up!
linusb is offline
parking break problem, i need my parking brake ClassicRiderhp TJ Wrangler Technical Forum 2 04-21-2010 09:21 AM
Parking Brake Problem Lee3333 YJ Wrangler Technical Forum 6 05-08-2008 08:13 PM
Parking brake problem exzebra TJ Wrangler Technical Forum 5 09-10-2007 08:37 AM
Brake Pads & Shoe recommendations? BNovak TJ Wrangler Technical Forum 2 07-27-2004 05:05 AM
Parking brake problem MusicMaverick YJ Wrangler Technical Forum 1 02-05-2002 08:07 AM
