8.8 / LSD issue - JeepForum.com
post #1 of 12 Old 09-15-2015, 07:47 PM Thread Starter
Awesome
8.8 / LSD issue
I stopped driving the Jeep a few days ago because I felt a drag on the way home from school one evening. It wasn't the front brakes, because it wasn't pulling to one side.
Anyway, with my busy school schedule I finally had time tonight to get under the Jeep and do some diagnosing. I tightened the oil pan bolts, because a few were loose and it looked like they were leaking. I found a LOT of ATF all over everything rear of the transfer case. It was leaking out of the speedo gear housing. The housing had shifted and the gear got chewed up (I installed a new gear a couple weeks ago). I re-installed it properly, filled the almost empty transfer case back up with ATF, removed my front drive shaft (needs to be replaced), and drove it down the street. Something is still dragging.
I checked the front wheels, they spin fine. The rear wheels, however......... the passenger side wheel spins okay, but does not spin the driver's side wheel at all. The driver's side wheel does spin the passenger side wheel, but it is very difficult to rotate and makes a metallic grating noise when I rotate it by hand.
The speedo gear housing is still leaking. Need a new o-ring, I bet. Anyone got any ideas on the axle? I think something is wrong with the carrier or the bearings, but I don't have time to open up the axle just to take a look. I am doing 80+ hours a week between welding school and work. I HATE driving my Blazer. Please help me figure out what is wrong with the Jeep so I can drive my baby again.
EDIT: I heard an odd sound like something shifting under the Jeep on two separate occasions. Once was going over a speed bump. I believe it was loose skid plate bolts, but not positive. I also heard a pinging sound, and THOUGHT something had either fallen off the Jeep, or a rock had flown out of the tire tread. The ping happened shortly before I started feeling the drag, but at the time I didn't connect the two.
Is it possible that one or both of the LSD springs snapped or came out of the carrier? That could account for drag, but doesn't explain why it would only be on one side.
100 Characters is not enough to have an interesting/relevant signature.
Awesome is offline
post #2 of 12 Old 09-15-2015, 10:43 PM
cyoos
Since you can't tear it apart at the moment to check it out I'll make a SWAG. It sounds like it might be the drivers side axle bearing.
As you stated, spinning the passenger side wheel has no effect on the drivers side, but when you spin the drivers side it is difficult to rotate and makes a metallic grinding noise but it does spin the passenger side wheel. That would tend to indicate a smoked axle bearing, which may very well have enough resistance that the lsd can't turn it; rather the clutches, especially if worn, are slipping rather than gripping.
Edit: This is, of course, barring any type of potential freak anomaly that may have occurred with your drivers side brake.
Last edited by cyoos; 09-15-2015 at 10:57 PM. Reason: Added potential cause of the condition
cyoos is offline
post #3 of 12 Old 09-15-2015, 10:58 PM
timatoe
timatoe's Avatar
I would tend to agree the problem is on the driver side in the rear, whether a bearing or a sticking caliper, it's on the driver side.
timatoe is offline
post #4 of 12 Old 09-16-2015, 05:42 PM Thread Starter
Awesome
I agree with the bearing diagnosis. I forgot to mention that I already ruled out the brakes. What is the procedure for replacing that bearing? Remove axle shaft, 3-jar puller? Is there a separate seal or is the bearing the seal?
Now I need to find a way to get it towed up to my dad's house so I can work on it in his garage after school one of these nights that I don't have to work.
Thanks for the help, guys.
Awesome is offline
post #5 of 12 Old 09-16-2015, 07:44 PM
cyoos
This is for a Mustang rear end I believe, but it's still an 8.8, and the only difference is the "wheel Sensor" for the ABS.
At step 8, you might find it beneficial to pop the old seal out before trying to remove the bearing.
http://diyford.com/ford-8-8-inch-axl...ide-step-step/
A quick video.
https://www.youtube.com/watch?v=Tr9JXP6w1ko
And you're very welcome!
Have fun!
cyoos is offline
post #6 of 12 Old 09-16-2015, 07:45 PM
timatoe
timatoe's Avatar
I haven't replaced one myself, but this looks pretty informative...... https://youtu.be/Tr9JXP6w1ko
timatoe is offline
post #7 of 12 Old 09-16-2015, 07:46 PM
timatoe
timatoe's Avatar
HaHa, apparently we both posted the same links.
timatoe is offline
post #8 of 12 Old 09-16-2015, 09:34 PM
cyoos
cyoos is offline
post #9 of 12 Old 09-17-2015, 08:39 AM
Randonexplosion
Deplorable
Randonexplosion's Avatar
Bearing puller and slide hammer. Both can be rented from Autozone. For the new ones they offer a "repair" bearing that has a built in seal, is bigger and rides on a slightly different part of the axle shaft.
Randonexplosion is offline
post #10 of 12 Old 09-17-2015, 08:40 PM Thread Starter
Awesome
Thanks guys.
I got out of school a little early this afternoon, so I stopped at Napa and bought a new bearing and some gear oil. When I got home, I couldn't find my three-jaw puller, so I had my wife - who was out - go rent me a slide hammer while I disassembled the axle.
I had the pumpkin drained and the axle pin removed. I removed the wheel and brake caliper, then tapped the rotor off. As soon as the rotor came off, a few big chunks of parking brake shoe fell out. By big, I mean one whole shoe and half of the other one.
So, that was the problem. Somehow the parking brake shoes failed horribly while I was driving... and no, I wasn't driving with the parking brake on.
Jeep is driveable again. Thanks guys.
Awesome is offline
post #11 of 12 Old 09-17-2015, 09:09 PM
cyoos
Thanks guys.
I don't think that's an all too uncommon condition with the parking brake shoes if they're pretty old. When I finally got around to tearing mine down the shoes on one side came out in pieces, and I seem to recall more than one thread on one of the explorer or ranger forums that discussed it too.
cyoos is offline
post #12 of 12 Old 09-18-2015, 04:14 AM
timatoe
timatoe's Avatar
Hmmm, mine are likely like that too. I drove my kid 9 miles to school one day with the brake on (yeah they hold that good) didn't realize it till I got off the highway and could smell it.
timatoe is offline
