8.8 limited slip what oil? - JeepForum.com
post #1 of 12 Old 09-16-2013, 10:23 PM Thread Starter
Dake
Dake's Avatar
What are you all running in yours and do you need to add the friction modifier?
Waiting on my Rough Country lift to sag!
Dake is offline
post #2 of 12 Old 09-16-2013, 10:25 PM
rykemc
Yes. Ford recommends using their additive.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #3 of 12 Old 09-16-2013, 10:25 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Luck Favours The Prepared
Anticanman is offline
post #4 of 12 Old 09-16-2013, 10:26 PM
Norcal_chris
Norcal_chris's Avatar
I ran plain 70-90 gear oil. No synthetic, no friction modifier.
Same as i did in my mustang back in the day. We would add the FRPP clutch packs and skip the modifier. All the friction modifier does is make the fluid "slippery" and allow the clutches to slip easier. Some people report issues of the clutches chattering but I never had an issue with it.
Ruined a perfectly good jeep.
OCT '13 & OCT '14 YJOTM 2014 YJOTY
Norcal_chris is offline
post #5 of 12 Old 09-16-2013, 11:05 PM Thread Starter
Dake
Dake's Avatar
I read some people on here filling it all the way to the front plug. Is this right? I had picked up some Lucas SAE 75W-90 Synthetic not sure if this is what I need after reading on here.
Dake is offline
post #6 of 12 Old 09-16-2013, 11:10 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Depending on your pinion angle and diff cover, you'll need to adjust the amount to cover your gears and lubricate the pinion. Some fill it to the brim. I fill it through the abs hole at the top til it comes out the front hole and then plug it off and give it a little more.
I wouldn't use the expensive stuff in the diff if you're gonna break in the gears and clutch packs. Or if you're like me and have water crossings that cover the front differential.
post #7 of 12 Old 09-16-2013, 11:27 PM
timatoe
timatoe's Avatar
Before putting the ARB in mine, I ran straight gear oil no additives. Well even after I still run it that way. I just meant when it had limited slip.
timatoe is online now
post #8 of 12 Old 09-17-2013, 12:23 AM
ashland82391
Just got an 8.8 today and there was a metal tag right on it saying to use only 75w140
ashland82391 is offline
post #9 of 12 Old 09-17-2013, 08:16 AM
tom_sprecher
Typically an LSD uses a friction modifier. The instructions that came with the Ford Racing LSD specifically stated to use non synthetic with a modifier. You can buy oil with or without it. You add the minimum at first and adjust based on how much chatter you get around corners.
I had a couple of bottles of Red Line's modifier left over from the race car so I bought 4 qts of NAPA 80W-? and added it per the instructions. There's a little chatter around sharp corners so it should be just right.
IMHO don't use a synthetic for break in oil.
Tom
tom_sprecher is offline
post #10 of 12 Old 09-17-2013, 10:31 AM
roadyrob
1987 YJ Wrangler
my 8.8 LS has a tag saying 75-90 synthetic, its out of a 99 mountaineer. fords recomended fluid must have changed with different years.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #11 of 12 Old 09-17-2013, 11:51 AM
tom_sprecher
Maybe the carbon discs in the Ford Racing part don't like synthetic.
Tom
post #12 of 12 Old 09-17-2013, 06:29 PM Thread Starter
Dake
Dake's Avatar
Mine had the tag! I had just took it off with out looking at it. That's what I filled it up with. Added the additive I got from advance auto. We see how it goes. l
Dake is offline
