8.8 install, driveshaft shortening - JeepForum.com
post #1 of 23 Old 12-08-2005, 07:22 PM Thread Starter
headkase
8.8 install, so lucky
One of the sites that has a write up on this said he cut down his own driveshaft and rewelded it. How safe it that? I am a competent welder and I do plan on replacing it when I do my HD SYE. Thanks
1992 YJ I6 5sp
4" RC lift / 33x12.50 MTR's / Custom front bumper with grille guard/light bar and rear bumper with tire carrier/ 8.8 rear, dana 30 front--4.10's / 1" custom lift shackles
headkase is offline
post #2 of 23 Old 12-08-2005, 07:29 PM
xeon
You just have to get it balanced and you are set. Unless its a trail rig only, then you dont need to worry about it too much.
88YJ, 350TBI, 700R4, Atlas 4.3, HP60, 14B (At a mall near you)
Tri-State (NJ-NY-PA) 4x4 Wheeling Group
xeon is offline
post #3 of 23 Old 12-08-2005, 08:25 PM
azgurney
Do a search on this. If you have a lift you do not have to shorten your driveshaft. I have a 2.5 lift with the 8.8 and my stock driveshaft worked fine.
91 Wrangler 4.0 5sp
8.8 4.10 explorer axle, 33x12.50x15 x-terrains,Rancho 2.5 lift and shocks, Goforit 1" motor mount lift, 1" body lift, sailcloth top with tinted windows
azgurney is offline
post #4 of 23 Old 12-08-2005, 08:55 PM Thread Starter
headkase
cool thanks. I will just have to check it out when I get the rear end. I just wanted to make sure I could do it.
1992 YJ I6 5sp
headkase is offline
post #5 of 23 Old 12-08-2005, 10:27 PM
Mr. Notorious
You won't need to shorten in if your have a 4" lift like your sig says. The only reason why it would be shortened is because of the flange adapter takes up like 1/2"-3/4". So thus making your d/s that much shorter. It didn't affect me at all. It actually helped because I think I was pretty much at the end of my slip yoke
1992 4.0HO 5spd -- BDS 3.5" lift -- 33x11.5 M/T's -- Gibson Cat-Back -- 8.8 with 4.10's -GONE
1967 FJ, linked, 350 chevy, 35's, arbs, blah blah...
2002 TJ
"If you're not moving ahead, you're falling behind"
Mr. Notorious is offline
post #6 of 23 Old 12-11-2005, 10:48 PM Thread Starter
headkase
One more question. If I reuse the perches from the 8.8, use factory explorer spring plates, then I just need to order some factory ubolts right?
1992 YJ I6 5sp
headkase is offline
post #7 of 23 Old 12-11-2005, 10:58 PM
jipjip
jipjip's Avatar
you need the factory yj spring plates, and shock mounts. then the 8.8 will bolt right in w/ new u bolts.
jipjip is offline
post #8 of 23 Old 12-11-2005, 10:59 PM
xeon
I think you will be able to use them. But they will have to be moved, if you didnt know that already. YJ springs are 2.5" wide, not sure how wide the Exploders are.
xeon is offline
post #9 of 23 Old 12-12-2005, 04:03 PM Thread Starter
headkase
Due to the larger diamter axle tubes, that require new ubolts, wouldn't you need the explorer plates due to the holes being further apart on the plate?
1992 YJ I6 5sp
headkase is offline
post #10 of 23 Old 12-12-2005, 05:12 PM
admar2
admar2's Avatar
or just do it the easy way and order the MORE kit which comes with everything ya need.
admar2 is offline
post #11 of 23 Old 12-12-2005, 05:15 PM
drexelsteve
yup, and the more kit is pretty good but if u can get the hardware from the explorer save yourself some coin.
13 Rubi
drexelsteve is offline
post #12 of 23 Old 12-12-2005, 06:10 PM Thread Starter
headkase
thats what Im trying to do. ~40 something bucks compared to 110.00
1992 YJ I6 5sp
headkase is offline
post #13 of 23 Old 12-14-2005, 06:30 PM Thread Starter
headkase
So, i just rcvd my 8.8 today that I paid 280 for shipped. Its was out of a 2000 exploder with 91k on it. I picked it up and it was COMPLETE!! It even had the exploder e-brake cables. Now Im just waiting on the MORE parts to get here to git er put in.
1992 YJ I6 5sp
headkase is offline
post #14 of 23 Old 12-14-2005, 06:39 PM
azgurney
If you are stating sua I would recommend cutting the MORE perches down to around 5". They will really flatten your springs and make the ride rougher if you leave them 7" long. I wish I would have known this when I did my 8.8.
91 Wrangler 4.0 5sp
azgurney is offline
post #15 of 23 Old 12-14-2005, 08:13 PM Thread Starter
headkase
roger, thanks for the advice--I will cut them down to 5". This does not have any ill effects on stability?
1992 YJ I6 5sp
headkase is offline
DIY XJ front driveshaft shortening for use as rear CV driveshaft on YJ Joe Dillard YJ Wrangler Technical Forum 43 08-12-2014 08:53 PM
Driveshaft shortening near Medina OH pmccoy9876 Wrangler General Discussion 3 12-01-2008 08:34 PM
Shortening Driveshaft Matt87YJ YJ Wrangler Technical Forum 5 04-19-2007 07:04 AM
shortening XJ shafts?? iwishihad1 YJ Wrangler Technical Forum 7 02-02-2007 08:25 PM
Shortening DS ?'s cspoffroad TJ Wrangler Technical Forum 2 08-28-2005 11:05 PM
