8.8 gear help. - JeepForum.com
post #1 of 11 Old 04-21-2014, 11:54 PM Thread Starter
cody413
8.8 gear help.
Hi I have a 92 wrangler with 2.5. I have 4.10gears
I found a axle in a explorer in good condition. There is no doors so I can't see the code for the gears. I looked on the tag on the cover. It said 4L10. That's 4.10
Gears and limited slip? Is that what looking for my swap?
cody413 is offline
post #2 of 11 Old 04-22-2014, 12:00 AM
SeanB95YJ
correct....
though it's unlikely, it's POSSIBLE the gearing could have been changed. since you should at the very least replace the fluid in it (which means pulling the cover), while you have the cover off, rotate the ring gear until you see stamped numbers on the edge... this will confirm the ratio. and while you're in there check the condition of the limited slip's S-spring inside the carrier. These can sometimes crack/break.
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 11 Old 04-22-2014, 11:00 AM
StanF
4.10 gears are tough to find in 8.8s - good find. What year Explorer? 1995-2001 is the best, as you get the advantage of a disc brake upgrade.
StanF is offline
post #4 of 11 Old 04-22-2014, 11:46 AM
SeanB95YJ
maybe it's a TX thing? when I grabbed mine, the yard had 8 explorers between 95-01... 6 of them were 4.10 and the other 2 were 3.73.
just look for the label on the door jamb and under "Axle code" will say either D2 (for limited slip) or 42 (for open)
if the label is gone or not legible, then the tag on the diff cover will have "4L10" (for LS) or "4 10" (open)
swap/build thread:
post #5 of 11 Old 04-22-2014, 11:54 AM Thread Starter
cody413
I think it's a 20 or 2001 and guy only wants $170 for it. Going to get it tomorrow.
cody413 is offline
post #6 of 11 Old 04-22-2014, 12:03 PM
SeanB95YJ
I don't know the market down there in FL, but around here that's not a bad price for a private sale or a full service yard.
swap/build thread:
post #7 of 11 Old 04-22-2014, 11:26 PM Thread Starter
cody413
Yeah it was from a yard where I found it.
But kinda off topic but my buddy has a older 350 (carbed) which runs.
What would be my best bet to get for tranny an T case?
Like a truck where I can just get both ?
cody413 is offline
post #8 of 11 Old 04-23-2014, 12:39 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What's the plan for tires, first?
Luck Favours The Prepared
Anticanman is offline
post #9 of 11 Old 04-23-2014, 01:13 AM Thread Starter
cody413
Well I have 33" now. Notnplanningbon going more then 35s.
I was thinking if the front axle can handle that not
cody413 is offline
post #10 of 11 Old 04-23-2014, 01:32 AM
SeanB95YJ
any GM full size pickup from 88 to somewhere in the early/mid-90s will have a 700r4 if it's an automatic, and behind that will be either an NP231C or an NP241C driver drop TC.
you can also get an S10 pickup/Blazer if it originally had a 4.3 motor - the bell housing is the same pattern, so that trans will work behind the 350 as well.
with 33s and even 35s you should be fine unless you go totally nuts on the power. an unmodified carbed 350 is rated somewhere in the low 200s. with "bolt-on" mods (intake, carb, headers, etc) you'll probably end up somewhere around 250-ish, which should be fine for most driving on 33-35s with the D30 front. the 8.8 has been used behind mustangs with much higher power than that.
Go for it
swap/build thread:
post #11 of 11 Old 04-23-2014, 08:23 AM Thread Starter
cody413
Well the engine he has ha a serious cam and bored 60 over so idk how much it will be pushing.
And either of them will work? Is there one I should try to find between the two.
Just trying to get as much info as I can.
Thanks
cody413 is offline
4.10 gears , 8.8 , swap
