8.8 explorer axle shafts ->discs in drums 1/8" difference - Page 2 - JeepForum.com
post #16 of 16 Old 04-06-2013, 09:03 AM
RockWoRM
RockWoRM's Avatar
Originally Posted by mrdeath2000 View Post
Drum brake 8.8 explorer axle shafts are 1/8" longer on each side than disc brake axle shafts. Fact.
With such a minute difference, I would think you could utilize disc brake axle shafts as spares right?
I'd assume that prolonged use would be bad because the drum wouldnt fully cover the shoe and create a groove?
Just food for thought...
Hmm, yea, the shorter length could make C-clips an issue or maybe require the s-spring removal if LSD.
strength is definately not an issue.
I was thinking of the drum brakes the wrong way, they may actually hit the backing plate without a spacer.
Interesting topic. I honestly didn't know there was a difference. I have the drum 8.8, but I also have a set of disc shafts I have kept around for spares 'just in case'. So now you've got me wondering if they will work in my case???
Another question... at which end are they longer>? The spline side from the C-clip grove, or the C-clip grove to the flange?
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
