8.8 Disc to Drums - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 8.8 Disc to Drums
Grizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! BroughYukon Ultimate 35 axle kit for c/clip axles with Yukon Zip
Unread 08-09-2014, 08:10 PM   #1
Louie4
Powah Injanir
Louie4's Avatar
8.8 Disc to Drums
I didn't find much on this but I'm thinking about swapping my 8.8 disc to drums. Mainly because the parking brake is crap with the disc and I don't think I will lose any stopping power with drums. I also think it will cost about as much for junkyard parts as the driveline disc brake setup. I was just wondering if I could bolt up a drum setup to my current disc 8.8 axle housing?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 08-09-2014, 09:10 PM   #2
StanF
I believe yes. The housings are the same. But I think you'll also need axles out of the drum 8.8.
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is offline   Reply With Quote Quick reply to this message
Unread 08-09-2014, 09:11 PM   #3
langwilliams
I converted a drum fox body mustang from drum to disk so I guess it works both ways. have you looked into a drive shaft/pinion E brake kit?
langwilliams is offline   Reply With Quote Quick reply to this message
Unread 08-10-2014, 07:09 AM   #4
jbolty
jbolty's Avatar
Some day I'm going to solve this problem. Why does the e brake work fine when the axle is in the Explorer, a bigger and heavier vehicle, but suck when it's in a YJ?
I wonder if the leverage design on the pedal is different?
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote Quick reply to this message
Unread 08-10-2014, 07:41 AM   #5
Louie4
Powah Injanir
Louie4's Avatar
In that case I'll snag some parts and see. I think the shafts are 1/8" difference in length but I think that may be negligible.
Yes but I think I can get all the parts for the same (or cheaper) price as the drums which are plentiful. I will also need to modify my NP231 output yoke and get a flange adapter for the driveshaft.
Let me know when you do. Are you still using the 8.8 e-brake or do you have drums? I put mine in gear and turn the tires into the curb because it makes me nervous even on the slightest incline. I can continue to tighten the e-brake tensioner but I think it's a losing battle.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 08-10-2014, 08:05 AM   #6
Jeepsr4me
I have not had that issue of the Ebrake. Either with a TJ or YJ. And I like to stop on steep drops and inclines.
I reuse the stock explorer cables and splice in with the jeep stuff.
Marking this for later since I sold the last jeep with 8.8 and will see how the next time goes.
Jeepsr4me is offline   Reply With Quote Quick reply to this message
Unread 08-10-2014, 09:59 AM   #7
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
It's the tires I think. Most people doing this have 35's. I left the discs in my 8.8 but completely gutted the Ford parking brake system and cables. Went with this. I used an overhead garage door cable pulley on a bracket welded to the side frame to turn the pedal motion 90°. Now it's 4.88 times (axle ratio) as strong as anything at the wheel. It's a Tom Wood kit.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is online now   Reply With Quote Quick reply to this message
Unread 08-10-2014, 10:07 AM   #8
xlTravislx
xlTravislx's Avatar
Im frowned upon in the 8.8 swap world because I purchased mine out of a 94 (with the drum brakes). Regurding the stopping power I would be surprised if you louse any. When I first drove with my 8.8 compared to the stock D35 breaks it was a huge difference. I haven't yet set up my e-brake (Florida is flat anyway). for now I just carry tire chucks whenever Im parked on a hill.
-White Jeep Club Member 231-
Replacing random parts on hunches spurred from other vehicles and peoples experiences with them is the safest bet.
xlTravislx is offline   Reply With Quote Quick reply to this message
Unread 08-10-2014, 10:35 AM   #9
Louie4
Powah Injanir
Louie4's Avatar
Don,
How much did that set you back, if you don't mind me asking?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Unread 08-10-2014, 10:45 AM   #10
JeeperDon
JeeperDon's Avatar
Here is the kit I started with. You need to have a flange type t-case output, not a yoke. I already have the flange style with my Tom Wood driveshaft and SYE kit. You also might have to fab the mount part on your own. In my case, the two black arms (one visible) were fabbed by me and welded to the rust colored round bearing holder of the SYE. I've had this in service for 8+ years I think. It has huge holding power, more than any other parking brake I've had on any vehicle.
Unread 08-10-2014, 05:03 PM   #11
Louie4
Powah Injanir
Louie4's Avatar
Gracias good sir.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
