8.8 cost of install - JeepForum.com
post #1 of 23 Old 10-17-2008, 01:22 PM Thread Starter
h2osprt
8.8 cost of install
So I got a quote from an axle shop that would put an 8.8 with disc brakes, locker, and gears for about 1500. Being that I'm not mechanically inclined and up to it myself does this sound like an ok deal? It's about half the price of a Currie with the same specs. Any thoughts? BTW I live in Long Beach Ca if anyone knows of a shop that might be cheaper/better.
Thanks
h2osprt is offline
post #2 of 23 Old 10-17-2008, 01:29 PM
MLJeeper
MLJeeper's Avatar
Which locker are they proposing to install?
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #3 of 23 Old 10-17-2008, 01:32 PM Thread Starter
h2osprt
the guy told me a detroit or truetrac
h2osprt is offline
post #4 of 23 Old 10-17-2008, 01:41 PM
MLJeeper
MLJeeper's Avatar
Well detroit/eaton makes the tried and true detroit locker and they also make the true trac which is a limited slip dif. So make sure your getting what you want. If the price includes the install, etc, a new ring and pinion and the detroit locker NOT the true trac, i dont think its a bad deal.
MLJeeper is offline
post #5 of 23 Old 10-17-2008, 01:41 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
The truetrac is not a locker - it's a gear driven limited slip.
http://nationaldrivetrain.com/shopsi...trac_ford.html
To give better feedback - what all are they doing? Are they doing the install only & you are supplying all the parts? Or something else?
Joe Dillard is offline
post #6 of 23 Old 10-17-2008, 01:44 PM
jeepster93
jeepster93's Avatar
I can tell you what is invested in My 8.8...
$1600
installed it myself, including the welding.
$400 for the 8.8 itself(I live in Colorado, where NOTHING 4x4 related is cheap)
$700 for the ARB locker
$100 for the diff cover
$50 for all new brake lines
$150 for new shock mounts and spring perches(I added a shock relocator for 3 inches of shock lift)
$150 for a ubolt reversal kit
$50 for this and that(fluid, gaskets, rotor turning that kind of stuff)
___________
$1600
It could have been done cheaper, but I did add a few...upgrades.
Cheap wasn't necessarily the ultimate goal though.
jeepster93 is offline
post #7 of 23 Old 10-17-2008, 01:53 PM
champelite210
900 for mine.
300 for 8.8
275 for aussie locker
100 for diff cover
125 for brackets
100 for misc
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump PSC steering Bx, XRC 8000 winch.
champelite210 is offline
post #8 of 23 Old 10-17-2008, 02:10 PM
SEZARO21
215.00 for mine.
80.00 for the axle
70.00 for the rotors
25.00 for the brake pads
10.00 for the calipers
30.00 for misc.
1991 2.5L YJ, 4" R.E. lift kit, 1-1/4" Lift shackles, K&N CAI, 4.0 TB w/ bored out intake, 5.0L Ford Mustang fuel injectors, 117A alternator, Ford Taurus electric fan, Rancho steering stabilizer, 8.8 Ford axle, 35x12.5x15 Dunlop Mud Rovers, Smittybuilt Titanium side steps, Smittybilt SRC Front Grille Guard Bumper, Smittybilt Stereo Center console, PIAA 520 Series fog lights, Sylvania Silverstar headlights, 20 gallon fuel tank upgrade & Herculined tub.
SEZARO21 is offline
post #9 of 23 Old 10-17-2008, 03:45 PM
RikRotorhead
Originally Posted by SEZARO21 View Post
215.00 for mine.
80.00 for the axle
30.00 for misc.
Damn that's cheap!
Zombies hate fast food.
RJC#512
RikRotorhead is online now
post #10 of 23 Old 10-17-2008, 03:47 PM
RikRotorhead
___________
Where did you get these items? Did you do a thread on your install? Pics?
RJC#512
post #11 of 23 Old 10-17-2008, 05:44 PM
RockWoRM
RockWoRM's Avatar
lets see...
109 for axle (drum)
50 for perchs/shock mounts
already had the MORE upper shock ext.
28 for ss braided brake line
20 for new brake shoes
fabbed my own e-brake cable coupler
IIRC, 225 for superior 4.56 R & P and install kit
250 for gear install labor
502 for full Detroit
85 for diff cover
95 for JKS ubolt plates
40 for u-bolts
$1404.oo/ Did my own welding/install
edit: forgot the yoke adapter... 20-30???
OP, make sure that price is for weld in w/new perch's and not a bolt-in job using the fac. perch, where as the springs will be pulled inward.
WRM
'05 LJR, 6sp, RC long arm w/MC 6" coils, 5.13 D44's w/chromo shafts, MetalCloak fenders/sliders/body armor, 37x12.50 MTR's, Warn 9.5, RockHard swing out w/full spare. <><
RockWoRM is offline
post #12 of 23 Old 10-17-2008, 07:57 PM
Matt Graham
Hater of Debt
Matt Graham's Avatar
Bought the 8.8 w/ 4.11's & discs for $150 from a salvage yard (came 100% complete including e-brake cables).
Reused the ubolts & plates & modified the plate for the shock mount for $0.00
Used the Ford brake lines for $0.00
Had some gear lube left over from a previous project.
Removed the Ford factory spring perches & reused them for $0.00
Driveshaft flange for $30
Shorten driveshaft 5/8" & balance for $65
Turned Rotors for $15
Did welding & labor myself for $0.00
Brake calipers & stuff were in good shape $0.00
TOTAL COST = $260 (I think that was everything)
Sold the Dana 35 for $350.
So I made $90 swapping to an 8.8. I was pretty excited about that.....I think the key is finding one that is in good shape with all the necessary stuff with the correct gear ratio already in it, but I know in some areas that can be difficult.
Instagram:
Twitter:
Youtube:
My Build Thread:
F-250 7.3 Tow Rig Build Thread:
Matt Graham is offline
post #13 of 23 Old 10-17-2008, 08:05 PM
93jeepREDSOX
300 for axle
200 parts
450 for a shop to put it in.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #14 of 23 Old 10-18-2008, 05:03 AM
Ipsteeler
$350.00 for 8.8
$20.00 Turning rotor's
$150.00 Gear's
$250.00 Aussie locker
$30.00 perch's
$25.00 Shock mount's
$35.00 Spicer Adapter
$15.00 gear oil
$20.00 .030 wire
$6.00 zinc primer (Help's with rust)
$2.00 Walmart special rattle can
All in All it ran me a grand total of $903.00.
The 8.8 was from a 2000 exploder with only 11,000 miles that was in a head on collision. SO new pad's and shoe's, Did not have to get master rebuild kit, Just the minor rebuild kit.
It also took me a total of about 12 hour's, So for $90.00 an hour (going rate in fresno, CA) for 12 hour's = $1080.00
If you dont have the tool's or the Fab skill's $1500.00 is not a bad deal at all.
Ipsteeler is offline
post #15 of 23 Old 10-18-2008, 06:15 AM
denalione
Originally Posted by 93jeepREDSOX View Post
950
300 for axle
200 parts
Who did the work for you?
denalione is offline
cost of sye/cv install? Mais das me! TJ Wrangler Technical Forum 11 06-28-2007 04:50 PM
Cost of install Negative6 TJ Wrangler Technical Forum 16 12-31-2006 11:20 PM
Cost of install on a BB twinjeep97 TJ Wrangler Technical Forum 13 07-17-2006 03:29 PM
cost to install? Negative6 TJ Wrangler Technical Forum 3 06-19-2006 04:47 PM
RE BB install cost JeepinJohnny TJ Wrangler Technical Forum 14 06-23-2004 09:22 AM
