*** 8.8 Consolidation thread *** - JeepForum.com
 2Likes
post #1 of 26 Old 05-15-2014, 11:20 AM Thread Starter
jbolty
jbolty's Avatar
Post any links or information here that should be included regarding 8.8 axle swaps.
Don't post questions regarding specific projects. This is meant to be for spreading information only.
Thanks
jbolty is offline
post #2 of 26 Old 05-15-2014, 12:35 PM
StanF
Here's my 8.8 swap thread:
http://www.jeepforum.com/forum/f12/y...xtras-1565339/
and Feetwet's too: (a very good one)
http://www.jeepforum.com/forum/f12/e...stall-1570466/
I have a lot of links to other threads and info here in my Appendix:
http://www.jeepforum.com/forum/f12/y.../#post15820719
StanF is offline
post #3 of 26 Old 05-15-2014, 01:28 PM
warthog312
Not sure if it's worth anything in current form, but there's some good ideas brewing in my thread abour the parking brake system on an 8.8... CLICK HERE.
There's also a few good links floating around in that thread for other 8.8 brake solutions and kits.
Click for build thread:
- 302//435//20//8.8
>>>the single greatest investment you can make for your jeep is to buy a good welder, and learn how to use it<<<
warthog312 is offline
post #4 of 26 Old 05-15-2014, 01:36 PM
cojab
Great idea. Heres a couple.
http://www.therangerstation.com/tech...8_8-axle.shtml
http://www.therangerstation.com/tech...le_codes.shtml
Those are ones from Anticanman that I have used. Good general 8.8 info in there.
cojab is offline
post #5 of 26 Old 05-15-2014, 03:40 PM
Louie4
I used sebastian22's 8.8 swap thread.
Ford 8.8 swap...Finally
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #6 of 26 Old 05-16-2014, 05:24 AM
Shadownwpa
http://www.jedi.com/obiwan/jeep/ford88.html
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is offline
post #7 of 26 Old 05-27-2014, 03:21 PM
tom_sprecher
tom_sprecher is offline
post #8 of 26 Old 06-06-2014, 05:19 AM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
May or may not help someone. I dont have a ton of pics from start to finish, but may be some brake line ideas for 8.8 SOA application.
http://www.jeepforum.com/forum/f22/i...l#post22590657
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #9 of 26 Old 07-29-2014, 08:01 AM
JEEP_Nut1218
Here's mine for what it's worth
http://www.jeepforum.com/forum/f12/m...-dumb-1346869/
'90 YJ with some stuff
I'm a pic whore, get over it.
JEEP_Nut1218 is offline
post #10 of 26 Old 10-23-2014, 05:40 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
If you want to delete the ABS Sensor the Freeze plug that fits in the hole is Dorman Part # 555-013
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #11 of 26 Old 01-06-2015, 06:32 PM
Jeepfreak81
Jeepfreak81's Avatar
These are the codes you will need when out shopping for your 8.8
Axle tag codes:
3L73 = 3.73 LS
4 10 = 4.10 open
4L10 = 4.10 LS
and so on
Door codes:
43 Open 3200 3.08
41 Open 3200 3.27
42 Open 4.10
46 Open 3.73
45 Open 3200 3.55
D4 Limited Slip 3200 3.73
D2 Limited Slip 4.10
L73 Limited Slip 3.73
Here's all the specs, measurements, and misc crap about the 8.8 you'll ever want to know.
Ford 8.8 specs:
Weight (complete assembly w/ brakes etc.): 174 lb.
Axle shaft strength: 6,500 (lb. ft.)
Drivers side Ford brake hose #:F5TZ-2282-A
Passenger side brake hose #: XL2Z-2282-AA
Bolt size (U-joint flange to yoke) is: 12 x 1.75 x 30 mm
Driveshaft Flange: Spicer Part Number 2-2-1379
Measurements:
O.D. of tubes: 3.250".
Tube thickness: .250" (some are .188”!)
Ring gear diameter: 8.800".
Ring gear bolts: 7/16" dia. (qty. 10).
Pinion diameter/splines: 1.625 / 30.
Axle shaft/splines: 1.320 / 31.
Rotor thickness (where it mounts to axle is .250").
Overall width 59.625" (the F8.8 is .950" narrower then a TJ Dana 35).
Hole diameter for ABS sensor in top of housing: .811".
Centerline of housing to C/L of pinion difference is 3.875" toward the P/S.
Pinion offset: P/S to C/L of Pinion, 27-3/4" (no rotor on axle), D/S to C/L of Pinion, 31-5/8" (no rotor on axle). (this measurement is 2.5" more offset to the P/S then a TJ Dana 35).
all taken from
http://members.cox.net/quanno/ford88.html (Now a dead link, but Quan used to be a person here back in the day)
there are comparison pics to the D35 there as well
also www.stu-offroad.com has TONS of info... not just on 8.8 axles
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #12 of 26 Old 01-29-2015, 02:52 PM
Partsmke
I just checked my YJ foot operated park lever vs my TJ lever. The YJ lever is 9" from pad to pivot with a 2" pivot to cable which equals 4.5 to 1 ratio. The TJ has a 13" handle to pivot point with a 1" pivot to cable or 13 to 1 ratio. This is almost a 3 to 1 advantage. The YJ requires you push with your foot, the TJ is pull with your hand which is a much easier procedure at least for me.
You could attach a bellcrank where the front cable end is located under the body that has at least a 2.5 to 1 advantage (5" from pivot being pulled by the front cable and 2" from the pivot attached to the rear cable(s)). The foot pedal will have to move quite far and it would be advantages to have an early GM rachet still pedal assembly. You could install a TJ style handle and be done with it.
Partsmke is offline
post #13 of 26 Old 04-22-2015, 07:42 AM Thread Starter
jbolty
jbolty's Avatar
East Coast Gear Supply Discussion
http://www.jeepforum.com/forum/f12/e...8-8-a-3083537/
jbolty is offline
post #14 of 26 Old 04-25-2015, 09:18 PM Thread Starter
jbolty
jbolty's Avatar
CYOOS sent me this in a PM
Originally Posted by cyoos
That earlier ebrake solution might be the same guy that posted in Jeeps Unlimited on page one of the following post under the name Avanteone:
http://www.jeepsunlimited.com/forums...for-a-Ford-8-8
"OK, before I get started, I know I should have taken pictures. You guys did some pretty good work and don't take this wrong, but I did mine WAY WAY simpler than the prior posts. All I did is disassemble my D35 brakes, take the little ebrake lever that the cables originally attach to, chop off the last inch or so, grind it flat and weld it on the ends of the little ebrake levers that stick out of the 8.8. Then I simply ran my original D35 XJ cables through the hole on the 8.8, and hooked them onto the ebrake levers like they were originally in the D35. This works perfect, have done it in a YJ and in my XJ on 8.8 installs. Took me about 15 minutes total for the install and very easy assuming you already have the welder there. John. "
The last post in the following one page thread by davsyjdd (with pic) is the best solution I've seen so far. It utilizes the factory YJ ebrake cables, and welding the YJ cable retention end of the D35's ebrake lever to the 8.8's ebrake lever.
http://www.jeepforum.com/forum/f12/8...ables-1871410/
My project 8.8 is setting in the back room awaiting rebuild. When I opened it up for inspection last summer I found pieces of a previous gear set, one pinion tooth busted, the LSD clutch steels on the ring side were spun and jammed between the spiders and the diff housing, and a gentle twist in the ring side axle splines. So it's back to plan A and a complete rebuild with a TrueTrac, 4.10's, and possibly c-clip eliminator kit hopefully before the end of summer, so I have plenty of time to research.
Cheers
Chris Yoos
In my travels on the net I found these parking brake cables for YJ's with a disc brake conversion.
The left cable is 32.75 inches.
The right cable is available in 69.75 or 70.5 inch versions for 1991-1995, or a 64.75 inch version for 1987-1990 YJ's.
Total cost less shipping for a 1991-1995 YJ:
$36.46 with the short right cable
$39.44 with the long right cable or the 87-90 cable
Considering the inconsistency people seem to have with the ECGS cables, and the headaches of figuring out how to either adapt their YJ cables to the Ford parking brake lever, or the Ford cables to their YJ's equalizer, this seems like it might be a worthy investment.
The cables are a little over half way down the page, item 33a.
http://www.jeep4x4center.com/jeep-br...r-yj/index.htm
Cheers
jbolty is offline
post #15 of 26 Old 05-12-2015, 11:59 AM
cyoos
This is somewhat pricey at $160, but it's another alternative to feeding the 8.8's calipers for those needing extra stopping power.
"...The BPM uses the excess fluid capacity available in the master cylinder bore to provide increased line pressure for the low volume requirements of a small piston caliper brake system, such as Ford Explorer, Corvette and GM rear disc brake calipers, and is ideal for use with rear drum brake systems."
http://www.ecihotrodbrakes.com/brake_pressure_multiplier.html
cyoos is online now
