8.8 brake ?? - JeepForum.com
post #1 of 3 Old 12-18-2007, 11:28 AM Thread Starter
syd45
8.8 brake ??
My rotors have some play in them when you put them on. Its like the stud holes are to big, you can move the rotor back and forth a little. I know I have the right rotor. Is there something I need to do to make them fit better?
syd45 is offline
post #2 of 3 Old 12-18-2007, 11:32 AM
MetZenDS
bolt the wheels on?
A LITTLE play is normal with most break setups (i do NOT have an 8.8) but there is such thing as too much play.
1989 Jeep Wrangler YJ- PARTING OUT-
MetZenDS is offline
post #3 of 3 Old 12-18-2007, 04:09 PM
northjeep
Jeep parking ONLY
northjeep's Avatar
as long as the play is only rotational and not eccentric.
That is, if your rotors center "pilot" hole is not fitting tightly to the axle cap (in the center) then you have a problem.
Twisting around the center is ok. Shifting away from center as BAD BAD BAD.
-NorthJeep - >> Just Enough Essential Parts
northjeep is offline
Replaced Brake Booster - now brake lights stay on Viking TJ Wrangler Technical Forum 4 04-11-2017 07:46 PM
Strange Brake Problems & Parking Brake issue Tmsnake1 TJ Wrangler Technical Forum 16 02-24-2012 08:19 AM
After replacing calipers and rubber brake lines, my brake is still stuck! Dmcastino TJ Wrangler Technical Forum 23 06-26-2009 12:21 AM
Stock brake lines don't bolt up to Van's Big Brake kit Red_ TJ Wrangler Technical Forum 6 06-17-2007 11:11 PM
8.8 Brake question - connecting to the exisiting hard brake line? BNovak TJ Wrangler Technical Forum 2 06-10-2005 03:25 PM
