#1 | |
8.8 axle info
hey so i blew up the dana 35 yesterday with 30" at tires. got 8.8 to install but how far do i move the spring perchs? i have researched and found that the rear drive shaft will be seating to one side more than the other. is this true and how do i need to seat the rear up? thanks for any info.
#2 |
#3 |
ok i looked at it and it does not say anything about the measurement to move the spring perches.
#4 |
Just grab your trusty tape measure and measure the difference. It is not that difficult and you will have the right answer much faster than you will get it on the forum.
Not being a smartypants just trying to help you get it done. Dwayne
http://www.bobistheoilguy.com/images/lucas/lucas.htm[url] Prevent Flat Tappet Cam Failure. http://www.hotrod.com/techarticles/engine/flat_tappet_cam_tech/oil_summary.html[url] http://www.compcams.com/information/whatsnew/NewsDetails.asp?ListHistoryID=1821071676 http://www.dctra.org/?p=79 http://www.cranecams.com/?show=faq&id=1 |
#5 |
thanks did not think it would be that simple
#6 |
don't fear the Jeeper
Actually, it's easier than most think. Before cutting off the old perchs, mark the 'outside' of each perch. After cutting them off, simply move the new perchs 'outboard' 9/16" each side. This is simply splitting the 1 1/8" difference between the two axles and it will line up the springs on a YJ just right!
edit note: of course, its always best to mock up the axle and double check everything before welding. WRM ![]()
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <>< |
#7 |
thanks. thats what i was looking for . ok next i am looking to put a rc 4" lift on later, this is my dd so i am trying to get it back on the road. can i set my pinion angle for the lift now or do i need to wait? and if i leave the angle like it is on the old axle will the lift kit degree shims angle it the way it needs to be? ok for the ones that has done the lift and 8.8 if i were to weld the perches for the lift now what will the angle be?
#8 |
Free clues & suggestions
The info is contained in the link.
Take another look at the "Semi Interesting measurements......chart". It's there. Look at the "Distance between spring perches (o/c)" line. It's the 9th item down on the chart. Take 40.5 - 39.25 = 1.25". Divide 1.25" by 2 = .625". This is the distance (on center) that they are too narrow on the 8.8 on each side. Move each of the perches outward from their stock position .625" & you'll be on-target. ![]() |
#9 | |
WRM ![]()
#10 |
would it hurt to go ahead and put a slit angle to it for the lift ?
#11 | |
#12 |
Hillbilly Member
you need to have your what lift you are going to put on it to properly set your pinion angle. I guess you still have a slip yoke on your t-case well you have to have a certain angle when running a driveshaft with a u-joint at each end and you will probably end up putting a SYE when you do a 4" lift then you will need to set your pinion angle completely different. when you get your lift and set your angle your pinion is going to be pointed a lot more skyward than it is right now.
To view the NEW Jeep Encyclopedia click here!!! |
#13 | |
Hillbilly Member
11 9/16 drivers side and 8 3/4 passenger side from the inside of the spring perch to axle housing where the axle tube goes in.
#14 |
Thanks for pointing him to specific line of the link. I thought he would find what he needed. He must still be reeling from that lost yesterday of his DAWGS!!!!!!!!
#15 |
Just remove the D35 and throw it away.
Place the 8.8 under the jeep, put the perches on the axle install the U bolts but do not tighten. Center the axle under Jeep and set pinion angle, double check everything. Tack weld the perches. Remove axle and weld perches to tubes, install shock mounts, perm install axle, hook up brakes install drive shaft using correct adaptor. Test drivem Drink Beer. Dwayne
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
