8.8 4L10 Rabbit hole - JeepForum.com
post #1 of 59 Old 01-17-2014, 02:28 AM Thread Starter
Gausswave
Started my swap in tonight. As with any project one thing leads to another and...
I started by taking off the brakes out and noticed a bit of end play in the axle shafts so I opened up the diff to have a look see. There wasn't much fluid. The scene was very black. The odd part was if you rubbed your finger on the gears the oil was relatively clean. Spider gears had a little pitting but no cracks. Ring gear looked and felt food. It felt like a ~tight diff from the git go. My best guess is the clutch packs are worn and will affect the end play but this is some thing I can't seem to find a definitive answer on. I measured the end play at .080" and .085". How much end play should you have on an 8.8?
Gausswave is offline
post #2 of 59 Old 01-17-2014, 07:38 AM
StanF
Not an answer, but a comment. From what I've read those LSD parts are really aggravating to get back into the carrier. Since it's already open, you might want to just install a locker. Might be easier in the long run.
Also, if you don't get any good help here, you might try one of the Explorer, Ranger or Mustang forums (since they all use 8.8s).
StanF is online now
post #3 of 59 Old 01-17-2014, 08:40 AM
tom_sprecher
Mine looked the same as you describe, everything was black. The clutch packs were worn so bad there was no resistance. I believe there should be something like 35-45 ftlbs. The spiders were seriously pitted and galled. After looking into the cost of new spiders and clutch packs it was cheaper to buy this.
It's hard to beat $219 shipped for a new carbon fiber Ford Racing LSD.
Tom
tom_sprecher is offline
post #4 of 59 Old 01-17-2014, 08:50 AM
Jeepsr4me
exactly what are you measuring? The amount the shaft pulls out of the end of housing or ring gear to pinion movement?
The axle will move a lot in and out. Normal. The factory clutches last about 25k give or take in the 8.8LS. There are better ones and better combos of installing them. Easy toa find on the net.
Jeepsr4me is offline
post #5 of 59 Old 01-17-2014, 10:36 AM
StanF
Here's a great page showing how to replace the LSD Clutch packs - it actually doesn't look too bad.
http://unitedpantherownersassociatio...r-still-in-car
He mentions end play, and the spec for it, at the end of the article.
StanF is online now
post #6 of 59 Old 01-17-2014, 10:47 AM
Dake
Dake's Avatar
Where did you get this from link please. Thanks
Waiting on my Rough Country lift to sag!
Dake is offline
post #7 of 59 Old 01-17-2014, 11:44 AM
tom_sprecher
Click on "this" in my post.
Tom
post #8 of 59 Old 01-17-2014, 12:37 PM
StanF
Don't forget the gear setup cost/hassle that comes with a new carrier...
A lunchbox locker could replace the spider gears without gear setup: http://www.jegs.com/i/Powertrax/754/92-0688-3127/10002/-1?parentProductId=
StanF is online now
post #9 of 59 Old 01-17-2014, 12:55 PM
tom_sprecher
The same site that has the Ford Racing LSD will sell you a new Ford Racing R&P for $139 and an install kit for $79. Add that to the cost of the LSD and the total is $437 vs. the lunch box locker for $521.
Granted it's not a locker, but depending on what your intended use may be, you get all new axle internals for pretty cheap.
Tom
post #10 of 59 Old 01-17-2014, 02:16 PM
StanF
I agree - I'm not in love with that locker, but it would not require any gear setups. Gear setups can be expensive, unless you can do them yourself. That's also the only lunchbox locker (as far as I know) that will drop into an LSD carrier.
And there are many advantages of lockers over LSD, and some disadvantages...the OP didn't really state what his intended purpose was (and his profile is very thin), so we're left guessing. I'm just giving him another option.
Even though I have an 8.8 LSD at the moment, I would rather have a rear locker. I don't want clutches in my rear LSD that may wear out/require maintenance/replacement.
If I was going to go to a locker, I'd probably buy a Detroit (which would require gear setup, BTW) for just a little more than the lunchbox locker. I'd love to have a selectable OX or ARB, but they are pricey!
StanF is online now
post #11 of 59 Old 01-17-2014, 02:44 PM
tom_sprecher
Although I would love to have gotten an ARB instead, I just could not justify the $$$$. When you add it all up they're close to $1200, maybe?
Tom
post #12 of 59 Old 01-17-2014, 02:51 PM
StanF
At least - probably $1500 with the compressor.
StanF is online now
post #13 of 59 Old 01-17-2014, 04:10 PM
NHfireLJ
NHfireLJ's Avatar
Just put new clutch plates in and be done... 8.8 LSD in rear and Aussie D 30.. Do all I need to do....
BTW, a 8.8 LSD needs a new carrier if you opt for a locker...and that means gear set up...$$$
SOLD
YJOTM FEB 2013
NHfireLJ is offline
post #14 of 59 Old 01-17-2014, 04:16 PM
StanF
Originally Posted by NHfireYJ View Post
snip
This is incorrect information - the Powertrax lunchbox locker that I referenced above is specifically FOR the 8.8 LSD carrier. It's the only one that I know of, but there is one...
StanF is online now
post #15 of 59 Old 01-17-2014, 04:37 PM
NHfireLJ
NHfireLJ's Avatar
Not sure how new that product is, but I see you are correct... However it looks like the part # you posted is for the F150.
This looks like the Explorer 8.8
1987-2010 - FORD 8.8 - 31 SPLINE - REAR 1822-LR 92-0688-3108 92-0688-3128
SOLD
YJOTM FEB 2013
NHfireLJ is offline
