79 ford f250 dana 60 direct replacment for dana 35? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 79 ford f250 dana 60 direct replacment for dana 35?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBds fox ipf 2.0 racing series shocks now available at rockSpartan Lockers FREE SHIPPING Excellent Prices
Unread 10-05-2010, 07:05 PM   #1
CDW_327
I found a dana 60 on craigs list, its got 4:10 gears, and the factory limited slip. for only $150 Just wondering if it would just bolt right up?
CDW_327 is online now   Reply With Quote
Unread 10-05-2010, 07:10 PM   #2
jsawduste
No
jsawduste is offline   Reply With Quote
Unread 10-06-2010, 05:48 AM   #3
chupacabrah
almost nothing "bolts right up". I can't really think of anything that does.
-Jon
'93 YJ with 1 ton SOA in progress (slowly).
Build Thread
jeep stuff
chupacabrah is offline   Reply With Quote
Unread 10-06-2010, 06:54 AM   #4
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
cut and paste from a doc I save.....
· Vehicle: '78-79 Ford Bronco, F-150, F-250 (reverse-cut D44 front, left-hand drop) (F-150 had 9" rear, F-250 had Dana 60)
Bolt pattern: 5 on 5.5" (Bronco and F-150) or 8-bolt (F-250)
Width: Way wide (~65")
Brakes: 11" discs
Spline count: 30-spline D44 front, 297 (large style) U-joint
Caster: ???
Other: 297-style U-joints are stronger than the EB flavor, and identical to the '95-present Wrangler D30. The reverse-cut gears are inherently stronger up front than standard-cut gears, and provide a higher pinion with a better driveshaft angle (just like the stock YJ D30). The Ford-style manual hubs are internally-splined rather than held on with 5 or 6 bolts like most others, which makes them stronger and less prone to leakage. They can also be combined with knuckles, spindles, and brakes from a '74-76 SJ or Chevy D44 to get the high-mount steering arms. F-250's had leaf-springs and 8-lug wheels, while Broncos and F-150's had front coils and 5x5.5" wheels. F-150/Bronco outers could be swapped into an F-250 axle to achieve leaf springs with a 5x5.5" bolt pattern, or you could just cut off the coil suspension bracketry (no small task) from an F-150/Bronco axle, or you could use an 8-bolt rear end to match the F-250 front. Another big drawback is the width of the axle. Cutting it down means a broken long-side axle shaft can only fixed with custom hardware. Then again, it could be cut to the same length as an SJ long-size shaft, allowing use of an SJ shaft instead of a custom-cut F-150 shaft. Front differential location (at least on F-150/Bronco) is identical to the early Bronco (3-4" closer to center than YJ D30). Like early Broncos, the stock tie rod / knuckle mounting holes lose turning radius, but this can be fixed with the high-steering mod. Most (all?) F-250's came with 4.11 gears. Some 1/2-tons had 4.11's, though most had higher gears. I don't know anyone that's done this swap on a YJ.
Poke is offline   Reply With Quote
Unread 10-06-2010, 07:57 AM   #5
Krochus
The only thing that "bolts right up" is gonna be a $1000++ aftermarket application specific axle. So you can just get that idea out of your head now.
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline   Reply With Quote
Unread 10-06-2010, 08:25 AM   #6
dan240
A Ford 8.8 from a Ford Explorer is the closest thing you are going to find to a bolt in axle. They have been swapped into Jeeps a lot. You can use the search function to see what's involved.
Good-luck
1994 YJ 4.0L 5spd
SOA, TJ Flares, 33" BFG MTs, Ford 8.8, SYE/CV
dan240 is offline   Reply With Quote
Unread 12-12-2010, 07:50 PM   #7
charlestrm
I might have one of those 8.8 ready to "bolt up" for sale." (its currently under my jeep)
~C.KING~
charlestrm is offline   Reply With Quote
Unread 12-12-2010, 07:55 PM   #8
turtlerace
Best taken in small doses
turtlerace's Avatar
1982 CJ7
Pretty sure it won't 'bolt up' to his YJ.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline   Reply With Quote
Unread 12-13-2010, 12:49 AM   #9
JFranko
Good-luck
Even those won't just bolt in. Still a little fab work that needs to be done. Generally, the only parts that will bolt up are parts that came from the same model. There are some exceptions, and axles typically aren't one.
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline   Reply With Quote
Unread 12-13-2010, 08:22 AM   #10
gearhead1985
no the axle will not bolt in
you will need new perches and shock tabs welded on
and unless you are running 35"+ tires you will hang up on every thing
but if you want to buy it and give it to me i will gladly except it
i want to put a pic here but the computer won't let me so here is the link
[url]http://i641.photobucket.com/albums/u...85/dnsjeep.jpg[/url]
gearhead1985 is offline   Reply With Quote
