79 cj 258 put into 95 yj - JeepForum.com
post #1 of 8 Old 12-26-2012, 03:10 PM Thread Starter
Challin009
Ok I need help, I drive a 95 yj with a 2.5l in it as a daily driver. I bought a really nice frame and tub from a 95 yj that was setup for a 4cyl. Now I also got a 79 cj 258 that I want to put in there. Including tranny transfer case and axles. I need to know what motor mounts to use for this and if I have to move the 4cyl frame mounts. Website links would be very helpful for parts. O'Reilys auto parts is close to me and Advanced auto parts also. Thank you For your time
Challin009 is offline
post #2 of 8 Old 12-26-2012, 03:50 PM
Old4X
1990 CJ7
Nothing bolt in available. New mount brackets need to be welded in
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #3 of 8 Old 12-26-2012, 05:32 PM Thread Starter
Challin009
So do I use old 79 motor mounts or do I use early '90s ,258 motor mounts
post #4 of 8 Old 12-26-2012, 05:53 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Save yourself some grief and check your local laws on this--many states require same year or newer on engine swaps to maintain equivalent emission standards.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #5 of 8 Old 12-26-2012, 06:13 PM Thread Starter
Challin009
Ok so you didn't help answer my questions. I just née dto know the straight facts on what I need thank you for your concern on emissions buti just want to know what motor mounts to use.
post #6 of 8 Old 12-26-2012, 06:17 PM
90DesertTanYJ
If your in a hurry, you might check over at pirate4x4.com. Real helpful and quick!
90DesertTanYJ is offline
post #7 of 8 Old 12-26-2012, 06:19 PM Thread Starter
Challin009
Thank you
post #8 of 8 Old 12-26-2012, 06:20 PM
Old4X
1990 CJ7
Pirate4x4 are the experts on this.
Old4X is offline
258 , cj , engine , swap , YJ
