75-77 F150 Dana 44 front axle question - JeepForum.com
post #1 of 22 Old 01-17-2007, 03:32 PM Thread Starter
93YJfalcon
Ok. I have a line on a 75-77 F150 Dana 44 front axle, but I'm concerned about the width and the bolt pattern. I have an 8.8 in the rear.
Question 1-
What are my options? I'm thinking either cut down the 44 to about 62" replace my 1 inch spacers in the 8.8 with some that match the 44 bolt pattern and get new rims. or cut down the 44 and get spacers for it that match the 8.8 (if they make any) and keep my rims. (I will also SOA and truss the 44 no matter what)
Question 2 -
Is there any issue with cutting down chromo axles? (I mean besides it being a shame).
Question 3 -
I don't want to go bigger than 37's (locked) Is there any chance that a 44 can take moderate abuse with that set-up without chromo shafts?
Having second thoughts....
Should I just get chromo shafts for my D-30, keep the same rims and accept the fact that I'll never go over 35's locked? That's not really cheap either. Dang it my pockets are already empty.
ROCK OVER LONDON... ROCK ON CHICAGO!
93YJfalcon is offline
post #2 of 22 Old 01-17-2007, 07:58 PM
themonkeyman
1987 YJ Wrangler
What exactly is the question again?
I don;t know for sure, but I know some of the D44's has cast C's, and thus could not be cut off and reused... not sure if you're in that window, but just a thought.
themonkeyman is offline
post #3 of 22 Old 01-17-2007, 10:05 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
you can buy weld on c's for your hp44..... but unless you have a jig you better leave the narrowing to a qualified shop.
the 44 will hold up just fine with chromo shafts and good u joints....
if i were you i would narrow the 44 to match the width of the 8.8 so you could eliminate the need for spacers all together.
when you shorten your chromo shafts, keep in mind the splines only go so far.... you may run into an issue with the splines being too short after you shorten the axle shafts if you have to shorten them too much... keep that in mind as well. note, that's not a huge problem and could easily be overcome with some ingenuity and/or money
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #4 of 22 Old 01-18-2007, 06:55 AM Thread Starter
93YJfalcon
Thanks man! Thats good to know. I don't suppose anyone knows if it matters if the axle came off of a vehicle with a full or part time t-case? Im guessing that if it is a part timer then there is a vacuum disco like the YJ. Can anyone shed some light on this?
post #5 of 22 Old 01-18-2007, 12:39 PM
fratis
fratis's Avatar
[QUOTE=Big-n-Broke-YJ]
QUOTE]
not possible for 2 reasons. after narrowing the 44 to under 60" wms not only is this too narrow for 37s but you will run into clearance problems for shocks and the like and the tires would be way too close to the body. it would be a waist of its potential to narrow it that much. more importantly with the current 8.8 he is going to need adapters. this is getting to the first question. no you cannot adapt the dana 44 to the bolt pattern of the 8.8. this is the problem with the 8.8 swap. the hub on the 44 wont allow for any smaller bolt patern then its 5 on 5.5. you could get the 8.8 flange redrilled for the better 5on 5.5 but you will still need spacers anyways as this axle assembly stock is way too narrow for 37s.
fratis is offline
post #6 of 22 Old 01-18-2007, 01:05 PM
drexelsteve
It should have locking hubs if it was a parttime axle, fulltime didn't.
13 Rubi
drexelsteve is offline
post #7 of 22 Old 01-18-2007, 01:24 PM Thread Starter
93YJfalcon
Oh. Ok, so if I want locking hubs (which I assume to be better/more desirable), then I want one from an F-150 with a part time t-case. I'm glad you told me that. The only one i've heard of lately would have been the wrong one.
post #8 of 22 Old 01-18-2007, 01:30 PM
92 Green YJ
92 Green YJ's Avatar
[QUOTE=fratis]
QUOTE]
or instead of that, you could get the Superior Super 88 kit. the flanges are already drilled and set for both 5 on 4.5" and 5 on 5.5" so that would solve the rear issue, not to mention the kit eliminates the c-clips and widens the axle back out to about stock Dana 35 width.
Also by design, the front axle is supposed to be a little wider than the rear axle. this has to do with turning radius.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #9 of 22 Old 01-18-2007, 02:18 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Actually.....there are less moving/wear parts in drive flanges than locking hubs. If you find one with drive flanges....get it, throw in some locking hubs and use the flanges as spares.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #10 of 22 Old 01-18-2007, 05:34 PM
fratis
fratis's Avatar
[QUOTE=92 Green YJ]
this would be his best option.
fratis is offline
post #11 of 22 Old 01-18-2007, 05:40 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
just to start a online fight.....
a hp 30 with chromo shafts/rubicon outers and a selectable locker will hold up fine with upto a 37" tire. i personally know lots of guys running that setup with zero issues, and yes they are real wheelers to dont baby around.....
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #12 of 22 Old 01-18-2007, 07:04 PM Thread Starter
93YJfalcon
No fight here. That's exactly the type of info I'm looking to dredge up. I am going to wait on it though and see what else materializes. I haven't taken polishing the 30 off the table yet. I'm just trying to do my research so that as axles become available I will know wether I should be interested and decide what they're worth to me.
post #13 of 22 Old 01-18-2007, 07:55 PM
fratis
fratis's Avatar
ill bite...but at the price of that you could build a nice 44. so why keep the weenie 30? btw why the rubicon outers?
fratis is offline
post #14 of 22 Old 01-18-2007, 08:01 PM
leftlanetruckin
XJ on 37's
larger u joints, i believe the same size as a 44!
for the price of a set of chromo's....i doubt you would be able to build a 44 for the same price.....
scott added the figures up for 30 spline chromo's, arb and gears....was a LOT cheaper than building a 44.
not sayin 44's are bad in any way, just my .02
post #15 of 22 Old 01-20-2007, 10:49 AM Thread Starter
93YJfalcon
I'm supprised. I would have thought the 44 would be cheaper. At least just to make it work. Not talking about upgraded shafts or anything. Is it the steering that boosts the cost up so much. I was figuring it would run about $2000 to beef up my D30. Putting in a 44 really costs more than that?!? I guess if that is the case I'm going to focus on my HP D30.
99 SE 2.5 dana 30 front axle question JeepJeep31 TJ Wrangler Technical Forum 1 10-04-2009 06:45 PM
Question about Dana-30 Front Axle Protoxis YJ Wrangler Technical Forum 8 08-03-2009 05:31 PM
'79 F150 Dana 44 High Pinion Front End schecterguy YJ Wrangler Technical Forum 14 06-07-2009 09:49 PM
Front Bronco Dana 44 Axle swap Question! jamesfromcanada YJ Wrangler Technical Forum 7 04-05-2006 10:05 PM
QUESTION: front axle(DANA 30) why does mine look like a DANA 35 713JeepTJ TJ Wrangler Technical Forum 5 03-06-2005 08:20 PM
