7/8 Heim Steering - JeepForum.com
post #1 of 39 Old 01-29-2012, 12:08 AM Thread Starter
jeepnbrett
7/8 Heim Steering
I've been running the Rugged Ridge steering kit with a Gopherit tie rod flip for about 2 years. All 4 of the rod ends are worn out. Rather than replace them I decided to upgrade to a Ruff Stuff 7/8 inch Heim steering kit.
HOLY CRAP this set up is beefy!!! Huge chromoly heims, 1.5 inch .25 wall tube, and stainless misalignment shims and spacers.
Starting with the obvious I measured the length of the current tie rod center to center of the bolts. The first tube was cut to length and then the threaded spuds were welded in.
Here's the tie rod ready to go.
The heims are mounted with 3/4 inch bolts so both knuckles and the steering arm need to be drilled out. In my case, I just had to remove the Gopherit inserts from the knuckles and I already had the 3/4 inch holes. I used a 3/4 inch drill bit and slowly drilled out the steering arm.
The tie rod assembly was put in place above the knuckle and a measurement was taken to determine the length of the drag link. The drag link was then cut and the spuds welded in.
Here are some pics of everything installed.
Everything is attached with 3/4 inch grade 8 hardware with nylock nuts and locktite. The bolts and nuts are not included from Ruff Stuff.
First test drive shows a noticeable difference in the steering. The dead spot due to the roll in the stock tie rod is gone. These parts are so over built that I will definatly break something else before the Ruff Stuff parts give way. These appear to be very high quality parts and an excellent upgrade. Total time to install including cutting, welding, and bolting on was about 2 hours. If your looking for a steering upgrade and have access to a welder I would highly recommend contacting Ruff Stuff.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #2 of 39 Old 01-29-2012, 12:35 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
What was the cost out the door with the new hardware included? I have the RR HD set up and I'm starting to regret it severely.
Luck Favours The Prepared
Anticanman is offline
post #3 of 39 Old 01-29-2012, 12:50 AM Thread Starter
jeepnbrett
With freight and the forum discount it was $273.00 delivered to my door. I sent Dan a PM and he gave me a code for a 10% discount to use at checkout.
It was cheaper to by the tube from Ruff Stuff and have it shipped rather than buying from my local metal supplier.
Brett
post #4 of 39 Old 01-29-2012, 12:54 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Looks like I'll be returning my RR kit and finally getting something that works.
post #5 of 39 Old 01-29-2012, 05:19 AM
timatoe
timatoe's Avatar
+ you can just pick it up, next time you're up this way.
timatoe is offline
post #6 of 39 Old 01-29-2012, 08:56 AM
lobukjeep
What size is the through hole in the heims on the right?They look a bit smaller.I plan on doing this on my buid.I already have a 20ft. of stick of tubing.These are the same ends i've been looking at.
"We don't call you son 'cause your bright"
lobukjeep is offline
post #7 of 39 Old 01-29-2012, 09:15 AM Thread Starter
jeepnbrett
Both tie rod ends use a 3/4 inch hole. Both drag link ends use a 7/8 inch hole. The drag link uses mis alignment spacers because of the angle and more required movement than the tie rod The mis alignment spacers adapt the hole in the end to from 7/8 to 3/4.
Brett
post #8 of 39 Old 01-29-2012, 10:28 AM
scifone
Learns the hard way
scifone's Avatar
I like the looks of this kit a lot. One question though, in the picture above showing the passenger knuckle it looks like you have the big end of the misalignment spacer facing down for the drag link. Shouldn't the big end be facing up to keep your steering from coming apart if a heim fails?
scifone is offline
post #9 of 39 Old 01-29-2012, 11:19 AM Thread Starter
jeepnbrett
Ummmm..... Good call. I'll switch that. 👍
Brett
post #10 of 39 Old 01-29-2012, 11:42 AM
dillonjm
2013 WK
Looks like a really nice setup, should hold up well to wheeling.
Nice Jeep too.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #11 of 39 Old 01-29-2012, 01:40 PM
ssyj94
I've been running my steering like this for a few years. It's alot stronger and durable than any tie rod end setup. The only thing I've been meaning todo is add a double sheer tab to the tops of the heims at the knuckles. But I havent had any issue with wallowing out the holes. You'll like it
My build:
ssyj94 is offline
post #12 of 39 Old 02-07-2012, 01:33 PM
95YJIL
Can you explain this to me? I'm a noob trying to figure it all out and love a good lesson.
95YJIL is offline
post #13 of 39 Old 02-07-2012, 04:46 PM
scifone
Learns the hard way
scifone's Avatar
On the passenger side knuckle there are some funnel shaped spacers. The top spacer on the draglink needs to have the larger end at the top instead of the bottom where it is. The reason being if the heim were to fail the body of the heim and the joint inside it could separate and the head of the bolt isn't big enough to hold it together. If that happens the heim could come loose from where it is bolted onto the knuckle and you would lose the ability to steer. By placing the spacer with the big end up would prevent the steering from coming completely apart if it were to fail.
Clear as mud?
scifone is offline
post #14 of 39 Old 02-07-2012, 06:04 PM Thread Starter
jeepnbrett
This is what it's supposed to look like. Big spacer on top.
Brett
post #15 of 39 Old 02-07-2012, 07:00 PM
dodger889
If you install heims correctly you would not have to worry about it coming loose. the insert part goes toward the in this case bottom. Solid part toward the bolt head. This just incase they where to fall apart that the solid part would not make it past the head of the bolt. In all reality there should be a metal loop that goes from the bottom of the bolt to just under the head of the bolt as a safety strap. This is on all heims single or doubled.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
