62 mm throttle body - JeepForum.com
post #1 of 4 Old 05-29-2013, 01:28 PM Thread Starter
stargazer3141
62 mm throttle body
Anyone have any advice here? My wrangler is a 91 with the 4.0 and am running a stock throttle body with a spacer and cold air intake. Anyone ever upgrade to a 62 mm throttle body? Good or bad idea? Worth the expense? Any brand/model recommended?
stargazer3141 is offline
post #2 of 4 Old 05-29-2013, 01:51 PM
jsawduste
2006 YJ Wrangler
Doable but not truly a bolt on.
Depending on your altitude and exhaust efficiency you may need to run larger injectors as the stock injector duty cycle will likely not flow enough fuel. Bumping the fuel pressure is a given no matter what.
One phenomena with the larger TB will be a pronounced flat spot in the low/mid RPM range. This is the Closed Loop ECM tuning at work and it is tough to totally eliminate.
I`ve finally got mine running what I consider to be pretty good after playing with timing, fuel pressure, injector phasing and throttle plate air bleeds. Even so the plan is to convert to OBD2 over the winter and have the ability to reprogram the ECM.
jsawduste is offline
post #3 of 4 Old 05-29-2013, 08:12 PM
superj
i went to one on a cherokee i had. it was a renix fuel injection system though so it was a little different. the oversize throttle body made such a huge difference that i ended up not regearing after going to larger tires
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 4 Old 05-30-2013, 11:19 AM
Siva283
Hope your gonna do a write up on the OBDII switch.
The throttle body spacer doesnt really help fuel injection.
Ask me how I know...
Siva283 is offline
