6 cyl tranny to a 4 cyl one??? - JeepForum.com
post #1 of 4 Old 02-27-2002, 03:45 PM Thread Starter
dartboy
dartboy's Avatar
Is it possible to bolt up a 4 cyl tranny to a 6 cyl engine. Guy I know has tranny problems. He has a 6, not sure if it is the 4,2 or the 4.0. Only tranny he has been able to locate is one from a 4 banger drive line. Will this work?
Jason
90 YJ...Stock for now.
74 Dodge Dart Sport
dartboy is offline
post #2 of 4 Old 02-27-2002, 04:12 PM
jerrys yj
the question isnt if it will fit, but if it is strong enough for the I6. ive heard that it wouldnt be able to handle it. if i were you i would just save the hassel and find an ax-15. but who knows i may be wrong but am pretty sure im not. -jerry
17 year old with a 1991 four banger
-3"RC lift
-32's on the way
-KC's on the windshild
personal quote:"it didnt look that deep dad, i swear!"(first time stuck in mud)
jerrys yj is offline
post #3 of 4 Old 02-27-2002, 05:40 PM
95yj-4 cyl
It won't work for 2 reasons (I'm sure about the 1st and heard about the 2nd). The 1st is because they have a different output shaft spline (21 vs 23), which also means the transfer case has to have a matching input shaft. The 2nd is they have a different bell housing pattern.
95 yj, 4 cyl, auto trans, 4:88 gears, detroit front locker, rear detroit with super 35 kit, short shaft conversion, 4" superlift, 32" superswamper radials
95yj-4 cyl is offline
post #4 of 4 Old 02-28-2002, 05:49 AM Thread Starter
dartboy
dartboy's Avatar
Ok guys thank, I will let him know. Jeep Parts are hard to come by in our neck of the woods. Junk yards don't want to part them out.
Jason
74 Dodge Dart Sport
dartboy is offline
How do I Remove Shifter from Tranny? Tranny Brace Question as well kgillette YJ Wrangler Technical Forum 17 09-12-2010 06:11 AM
Over filled tranny fluid 2 weeks ago, Now tranny problems chaznad TJ Wrangler Technical Forum 1 03-30-2009 06:10 AM
Should I repair Tranny seal or replace Tranny? Yankee-Juliet YJ Wrangler Technical Forum 10 03-29-2009 04:41 PM
tranny mount to tranny bolt size? pic inside dream911tommy YJ Wrangler Technical Forum 4 05-30-2008 08:16 AM
How much heavier is an auto tranny than the manual tranny? CB3 TJ Wrangler Technical Forum 9 12-24-2007 06:35 AM
