5th gear while towing? - JeepForum.com
post #1 of 10 Old 07-30-2002, 05:53 AM Thread Starter
white sox bill
Will be towing an aprox. 1000lbs trailer soon and was wondering what evreyone's POV on when, if ever, to shift into fifth gear. Do I look at RPM's or MPH? Is it easier on motor to have higher rpm's or lower? Any other opinoins appreciated and Thanks
1989 YJ Inline 6 cylinder 4.2 liter
white sox bill is offline
post #2 of 10 Old 07-30-2002, 06:11 AM
RICK'S92TJ
I went to Silver Lake, this past June, and pulled a trailer. It wasn't 1000 lbs, maybe 800 lbs. I hardley used fifth gear, except on the flat streches of highway. I kept my speed to around 60 MPH. I took my time and didn't push my 4 banger and every thing was ok.
92 black yj, 2.5 l 4 banger, 3.5 inch BDS suspension lift, 2 inch body lift, 33X12.5 BFG AT's,
RICK'S92TJ is offline
post #3 of 10 Old 07-30-2002, 07:45 AM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Watch your RPM's of course for the shifting, the the speedo for the cop's sake.
As long as you can keep your engine in the power zone (2000rpm to 2500rpm) or above, you shouldn't have any problems using 5th.
If your RPM's drop below 1900, I would consider using 4th. With a thousand pounds behind you, I would just take it easy, enjoy the ride .. do 55 the whole way
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 10 Old 07-30-2002, 09:54 AM
Jeepfreak81
Jeepfreak81's Avatar
i totally agree with naekid, i pull my homebuilt jeep trailer (take a gander flt fenders and yj wheels) with my 4 popper -- i went to silver lake with it, i pulled about 65 -70, the trailer originally weighed when i built it 450 lbs, before the sides,deck and ramps on the back, but then i switched axles which dropped the weight to still around 450 even with the sides and stuff on this time though, with my quad and gear in the back i figure it was around 1000 lbs, but as naekid said as long as you keep the rpms above 2000 you should be ok in 5th, any less drop her down, you will know when your pulling it when you need to do what, anyway enjoy the trip
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #5 of 10 Old 07-30-2002, 10:05 PM
NaeKid
NaeKid's Avatar
Hey JeepFreak,
Love the look of that trailer .. love them rims! Wanna make me one?
Actually, I have been thinking about getting the Rubicon trailer .. it looks way too cool .. what do you think it would look like with matching 38" tires on it? They do say that they will put any tire and rim to match my Jeep on it for no extra cost
Silver
NaeKid is offline
post #6 of 10 Old 07-31-2002, 05:12 PM
Jeepfreak81
that rubicon trailer is AWESOME, i want one now.... but the stress on that hitch in the one pic... unless its a special hitch wow... origianally had matching 30's on mine... but took them off -- i had them on different rims with hubcaps but the center of the rim stayed bolted to the hub and the wheel broke off going down the road.. so i re did the suspension and bought an axle specifically for those wheels, the rear ramp(s) folds up seems to work well, the frame was snagged from an 30's horse trailer and heavily modified, there was no suspension for one originally axle welded to the frame... i essentially rebuilt the trailer from that rebuild with the jeep theme and lots of cutting and welding, its BARELY the size of a 4x8 sheet of plywood, half the gate is removable with quickpins so you can chain the gate flat and hold longer items, id build one for you lol if i had another frame to start, it was expensive enough doing what i did! that and it would give an excuse for a trip out to that side of canada, i have a friend on vancouver island lol... but i dont know how my g/f would like me seeing her!
post #7 of 10 Old 07-31-2002, 06:53 PM
NaeKid
NaeKid's Avatar
There is some great wheelin' on Vancouver Island .. my brother used to be a Forestry Engineer based on the island .. and my sister still lives there (she is manager of one of the largest auto-part stores in Victoria).
I have a boat trailer that I am trying to sell so that I can build up a new trailer for wheelin', but I am not having any luck so far. I would have figured a boat trailer for a 16' motorboat would sell instantly .. and all I was asking was $800 .. new this thing is worth around the $1200 mark .. so the trailer continues to sit and await someone wanting it more than me ..
Silver
NaeKid is offline
post #8 of 10 Old 07-31-2002, 09:04 PM
Jeepfreak81
modigy that shorten the tongue, add some cross braces, maybe shorten the frame, put on the deck and big tires your set i made it sound easy didnt i???
post #9 of 10 Old 07-31-2002, 10:46 PM
NaeKid
NaeKid's Avatar
Believe it or not, that is basically what I was thinkin' .. but then I figured I needed a Chevy 6bolt axle to match mine, and cross braces need to be either welded or bolted in (its a fully galvanized trailer) .. my chop saw would be needed to turn the tilt-trailer into a non-tilt version .. and .. someone could really use a proper boat trailer, and I could use a proper "utility" trailer .. maybe trade it for a tent trailer .. hmm ...
Silver
NaeKid is offline
post #10 of 10 Old 08-01-2002, 09:31 AM
Jeepfreak81
ha ha whats funny is i have a chevy 6 bolt sitting out back... its the one i took off, i didnt need anything that heavy right now anyway... 58 chevy 6 bolt i also didnt have a spare and the trailer is kinda small to mount one so i made the trailer so i can use my jeeps spare, which in your case is that 6 bolt... lol that 6 bolt had very old bearings in it, they are $150 PER SIDE, so i swapped the axle for 80 bux, even though they wernt bad, i figure when i can afford to replace those bearings i will use that axle on another trailer. I can see where your coming from with the boat trailer, i just hope you can get what is worth... i know there isnt much of a market here in michigan for just boat trailers, and this is the great lake state-- most companies throw in the trailer anymore around here
Flat Towing the Rubicon, what gear??? blackjeeprubi TJ Wrangler Technical Forum 15 01-14-2011 08:52 PM
Dana 44 rubicon rear limited slip gear oil, synthetic or regular gear oil what weight rutacon05 TJ Wrangler Technical Forum 6 09-16-2009 08:53 AM
Flat towing manual trans. in gear, why? daveg13 TJ Wrangler Technical Forum 3 06-20-2008 04:11 PM
Gear Ratio for Boat Towing JKNY JK Wrangler Technical Forum 5 05-24-2008 08:16 AM
Use 5th gear when towing? Go Juice TJ Wrangler Technical Forum 16 07-26-2005 10:15 AM
