#16 | |
I have a tired old 2.5 and 32's and can hit 80+ MPH.
I can use 5th gear on the highway as long as I'm not going up a steep hill. Oh yeah, and i have stock 4.10 gearing as well.
1995 YJ 2.5 - 4” RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap My build thread... I've got a shotgun, a rifle and a four wheel drive... |
#17 | |
Something to consider is that the cost difference of re-gearing with existing weak axles is not much different then doing an axle swap upgrade. If you go with the common swap of the ford 8.8 *(Explorer Axle)* upgrade, you also get rear disc brakes to boot. The only fab work for this upgrade is to grind off and relocate the spring perches a half an inch each side.
There is no problem that can't be fixed if you throw enough money at it. |
#18 |
i would never wanna go 80 in a jeep
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
