5 speed transmission fluid question - JeepForum.com
post #1 of 23 Old 08-24-2011, 11:52 AM Thread Starter
02grandy
02grandy's Avatar
i have a 92 wrangler 2.5l with a 5 speed it looks like it takes 75/90w from the book but can i use 80w/90??? and does gear oil go bad? ive had an open bottle almost full for about 5 years maybe more . is it still good? thanks. im using it to top off from replacing the reverse switch.
02grandy is offline
post #2 of 23 Old 08-24-2011, 11:57 AM
TheNewbie
The new spec for the AX-5 (the 5 speed behind the 2.5 in your 92) is plain old 10W30 motor oil.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #3 of 23 Old 08-24-2011, 12:02 PM Thread Starter
02grandy
02grandy's Avatar
i kinda want to get rid of this bottle lol i dont know whats in there smells like gear oil. but if he has regular oil can you mix and can i still use 80w over 75
02grandy is offline
post #4 of 23 Old 08-24-2011, 12:14 PM
TheNewbie
That I don't know. I know you can mix engine oils. Like mixing a 10W30 and a 10W40 to get 10W35. But I don't know about gear oils. I would assume it's just a thicker version of the oil used for engines and could be mixed. But IDK for sure.
post #5 of 23 Old 08-24-2011, 01:17 PM
TheRobster
I am swapping mine to 10w30 this weekend.
Hopefully it will smooth the shifting a little bit.
Check out my cheep bastard Jeep mod blog.
TheRobster is offline
post #6 of 23 Old 08-24-2011, 01:27 PM
TheNewbie
It smotthed mine out. I swapped to 10W30 from whatever was in there from the PO (probably the origional fluid) and it went from feeling kind of "toothy" to shifting like butter.
post #7 of 23 Old 08-24-2011, 02:39 PM
TheRobster
Well, mine is about 4 years old. I had it changed just shortly after I got my YJ.
Of course they probably filled it full of 75/90w
Mostly I am changing it because about a month ago I went to Mr. Lube, and declined then when they wanted to change my trans oil. Now suddenly my trans is whining. This is the third time I have had a problem right after seeing them. I will not be going back again.
post #8 of 23 Old 08-24-2011, 02:45 PM
PA_YJ19
10w-30...doesnt matter what brand, did wonders for mine....
PA_YJ19 is offline
post #9 of 23 Old 08-24-2011, 03:57 PM Thread Starter
02grandy
02grandy's Avatar
i didnt have the star socket to open the side and couldnt find anything else so i took the shifter off and fill it like that to what came out when i replaced the reverse light switch. i use 80-90 i had around since i think thats what was in there from the smell and thickness. i had the cover off from a clutch job so it was easy
02grandy is offline
post #10 of 23 Old 08-24-2011, 04:07 PM
giggityjeeper
made mine shift worse, its harder now.... going back to gear oil...
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #11 of 23 Old 08-24-2011, 05:11 PM
TheRobster
I will be finding out in the next few days.
post #12 of 23 Old 08-24-2011, 08:15 PM
plym49
Respectfully disagree. If you mix one quart of 10W-30 with one quart of 10W-40, then you have one quart of oil that behaves like 10W-30 and another that behaves like 10W-40. This is not the same as oil blended to be 10W-35 from the get-go.
plym49 is offline
post #13 of 23 Old 08-24-2011, 08:53 PM
dancytron
If you use gear oil, make sure it is not the kind that messes up the brass syncho gears. Search, there are threads on it.
dancytron is offline
post #14 of 23 Old 08-25-2011, 06:24 AM
hrt4me
do I also have an AX-5 in my '91 YJ with 4.0L I6?
hrt4me is offline
post #15 of 23 Old 08-25-2011, 08:00 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
That would be an ax-15. Same 10w30 spec on oil.
I changed mine out and it was terrible! Then I removed the t-case drop and suddenly the tranny shifts like butter. I suppose you have to make sure the transmission is able to use whichever oil you choose to run.
Luck Favours The Prepared
Anticanman is offline
Six Speed Transmission Fluid Ichabod1960 TJ Wrangler Technical Forum 16 08-04-2016 08:42 PM
2006 6-Speed Transmission Fluid Top Off PSYCH0 TJ Wrangler Technical Forum 0 10-14-2008 05:53 PM
Transmission Fluid Question Jstin120 TJ Wrangler Technical Forum 3 05-03-2008 10:54 AM
Whats the best transmission fluid for my 04 sport 5 speed? JEEP-DADDY TJ Wrangler Technical Forum 7 06-28-2007 04:03 PM
Fluid for 6-speed transmission CLAYSHOOTR TJ Wrangler Technical Forum 6 10-11-2005 08:38 PM
