5 speed to Automatic - Page 2 - JeepForum.com
post #16 of 22 Old 08-07-2011, 07:23 PM
ZeroGravity
Originally Posted by Dre40 View Post
-This is "Dre40"'s daughter-
Thanks for all your guys help I'm pretty sure I'm going to get the YJ. It's an excellent deal, and the clutch is super easy to do, I'll just have to get to know the whole shifting part. As much as I'll miss my much loved Cherokee, I'm excited to try out, and hopefully enjoy a Wrangler :]
Driving standard isn't as hard as people make it out to be. You'll get used to the shift pattern after the first couple times you take it out.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #17 of 22 Old 08-07-2011, 08:30 PM
Xpress
x3 with the 4 low.
Getting into gear is just about the hardest part. From there is all about knowing when to come off the gas and push the clutch in, then moving the shifter to the right gear. All I can really say is don't move the shifter until the clutch is all the way in. When you get good, you can start to syncro the gears, or basically shifting without the clutch.
1st and 2nd need to be found by pushing it to the left, and pushing forward for 1st, or pulling back for 2nd. 3rd and 4th gear basically find themselves, just push it or pull it and it generally finds itself. 5th gear you really won't use unless you're cruising on the freeway, and I really only use it on long flat sections or downhill bits.
Don't be afraid to take that engine to 3500rpms either before you shift, they're made to run at that RPM range all day long.
Other than that, definitely learn on a big dirt lot in 4 low- it's gotta be in dirt because of the way the 4WD system works, so the front tires can slip slightly. Try it on concrete and turn hard- you'll see what I mean
The Jeep will only top out around 35mph in 4 low and 5th gear wide open, so you can take things slow enough to learn how the gears work. That's what I did when I first learned. When I moved to the road and into 2 high, everything just came naturally.
All about that unibody life.
Xpress is offline
post #18 of 22 Old 08-07-2011, 09:18 PM
smizar
And remember, it won't drive like your Cherokee, this was what happened to my daughter when she wasn't careful with one if mine
smizar is offline
post #19 of 22 Old 08-08-2011, 10:53 AM
Matt The Hammer
Added plus to having a manual shift is that none of your friends can borrow it.
In my case, my wife....
2013 JKU
1995 YJ
Matt The Hammer is offline
post #20 of 22 Old 08-08-2011, 11:44 AM
Xpress
x2
Xpress is offline
post #21 of 22 Old 08-08-2011, 11:57 AM
95laredokid
Tell her a 19 year old guy on your forum learned from his girlfriend in highschool and its easy to learn and she will love it and won't ever wanna go back.....well atleast I don't
95laredokid is offline
post #22 of 22 Old 08-08-2011, 01:14 PM
carln1210
1994 XJ Cherokee
Dre40's daughter~~
Thanks for you help guys. This is actually his daughter, thought it'd be fun to make an account. I appreciate all your guys help like I said earlier. I'm excited to get it, and Ill keep ya posted if/when I do! I think it'll be a great skill to have [driving manual], and you're correct, none of my friends will be able to borrow it, for sure.
carln1210 is offline
why is the automatic four speed such a... df04jeep TJ Wrangler Technical Forum 18 11-19-2010 11:07 AM
5 Speed VS Automatic mark12010 Wrangler General Discussion 3 04-30-2009 04:05 PM
3 speed to 4 speed automatic swap? vr6mole TJ Wrangler Technical Forum 10 06-12-2007 12:35 AM
5 speed or automatic Fr87hN TJ Wrangler Technical Forum 11 01-15-2007 04:35 PM
3 speed automatic? FSU Jeeper TJ Wrangler Technical Forum 14 07-25-2006 01:02 AM
