5 pole relay - JeepForum.com
post #1 of 9 Old 04-14-2013, 07:24 PM Thread Starter
scottontherocks
5 pole relay
I getting ready to install LED lights on my bumper. I have the relays, but I don't know what the middle pole is for?
Red- led lights
Brown- ground
Yellow- fused power input
Blue- switch
Black- ?
scottontherocks is offline
post #2 of 9 Old 04-14-2013, 07:32 PM Thread Starter
scottontherocks
The witch has 2 power poles and 1 ground. Do I rin the black to the second power plow on the switch?
post #3 of 9 Old 04-14-2013, 07:38 PM
Stud_man50
if you look on top of the relay it should have the wiring diagram, 87a the middle pole is constant until the "trigger" between 86 and 85 happen then the constant becomes 87 pole. The poles are always number on the bottom with tiny numbers. That is a normal install.
Stud_man50 is offline
post #4 of 9 Old 04-14-2013, 07:40 PM
Stud_man50
when you turn on the positive trigger the middle pole 87a shuts off.
post #5 of 9 Old 04-14-2013, 07:42 PM Thread Starter
scottontherocks
Great. Thanks for the quick reply.
post #6 of 9 Old 04-15-2013, 07:34 AM Thread Starter
scottontherocks
On the switch in the cab there's two poles for power. Do I splice into # 85 for both of those or run one from #85 and another from a fused positive wire.
post #7 of 9 Old 04-15-2013, 10:03 AM
SeanB95YJ
if you're just doing LEDs, why even bother with the relay? LEDs hardly draw anything
unless you're running like a million of them
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #8 of 9 Old 04-15-2013, 11:40 AM Thread Starter
scottontherocks
I've read that when running off road lights, if you don't have a relay, it will over heat and possibly melt the switch.
So...If I connect one of the posts from the switch to the relay and the other direct to the fuse cluster, then wouldn't that defeat the purpose of the relay. I'd still have one wire going direct to the switch.
post #9 of 9 Old 04-17-2013, 08:39 PM
bigbossd1030
That is not what relays are for. They prevent parasitic drains, plus act as a sort of fuse if you will. You will always have a power wire going direct to your switch. Follow the diagram above. As for that middle relay, it's not needed. I never use it for any of my lights.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
