5.9 Swap - JeepForum.com
post #1 of 75 Old 02-04-2014, 04:58 PM Thread Starter
JCashen
5.9 Swap
Good afternoon gentlemen,
I just picked up the 5.9 magnum out of a 97 dodge to swap into the heep.
My main question is regarding efi vs carb. A guy I've been talking to swears up and down that a holley 750 would provide more power and effeciency over the stock efi setup.
I'm not to worried about the wiring aspect of the swap but would like some opinions.
Once I get it home and on a stand I'll try uploading pictures of the ol' gal.
"Drippy"
90 YJ 5.2 Magnum MS3x, D60/GM 10.5", ORI struts, 4 link
JCashen is offline
post #2 of 75 Old 02-04-2014, 05:08 PM
metalhead
2011 WK
There is no way a carb is more efficient than efi. A carb just dumps a metered amount of fuel in depending on jet size. Efi uses several sensors and such for the injectors to spray the proper amount of fuel in. Plus when offroading you don't have to worry about off camber situations and starving the engine for fuel. With efi you will always have the proper amount of fuel. People think fuel injection is so complicated. It really is not. Carbs to me can be so hard to get to run right. With efi the computer does the tuning.
metalhead is online now
post #3 of 75 Old 02-04-2014, 05:38 PM Thread Starter
JCashen
I know there are guys on both side of the fence, and I don't want to start a flame war either.
My grandpa is old school with the 750 double pumpers he had on his z28. He also thinks we should go carb since then we could later put a cam in and just reject instead of messing with the computer. Also in the time saved not doing the wiring and possible down time if I wire it incorrectly.
This is currently my DD but won't be once I go to boot camp.
"Drippy"
JCashen is offline
post #4 of 75 Old 02-04-2014, 07:40 PM
YJ4LIFE
hows that carb on the 4.2l. fun? fuel efficient? Rebuilding it every few years? The efi will pay for itself and be 1,000,000x less hassel.
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #5 of 75 Old 02-04-2014, 07:55 PM Thread Starter
JCashen
I agree that's why I went with this instead of a carved 350. I still plan to go efi, just wanted to see some opinions.
I wasn't able to get it unloaded tonight. I don't think the neighbors would appreciate us running the forklift at 9pm
Will post pictures tomorrow, and bust into the engine to see what I got. Supposedly it was rebuilt 6k ago.
I still have to get motor mounts, fuel pump, harness, computer, bell housing, input bearing retainer for the slave swap, and any misc stuff required.
"Drippy"
JCashen is offline
post #6 of 75 Old 02-06-2014, 03:49 AM Thread Starter
JCashen
Sorry for the crappy pic.
The engine is suppose to be good. I can hear the compression when I turn the crank by hand.
Is it worth the cost in gaskets to make sure?
"Drippy"
JCashen is offline
post #7 of 75 Old 02-06-2014, 07:59 AM
Mark05059
did it come from a salvage yard or private sale. If its a salvage yard then just stick it in since it will have a warranty anyway.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #8 of 75 Old 02-06-2014, 08:49 AM
skyj
Good choice on a Motor I just installed a 5.2 from a grand cherokee with unkown miles and unknown condition, so I did a cylinder leak down test (best way to confirm its good) on it and the worst cylinder only had 15% leak which is really good so I slapped it in. Sure I've had a few wiring snaffoo's with my swap and a few sensor headaches but it still beats the piss out of that stuipid carb setup I had on the ol 4.2. Besides all of the wiring really isn't all that bad sure it takes a little bit of knwledge of reading schematics and what not but anybody can do it if they set their mind to it. I went into my swap with no understanding of the wiring, but with great help and encouragment from this forum I have been able to figure out everyone of my problems and now I got a fuel injected jeep that runs like a raped ape!
Dont listen to the naysayers stick with the MPI and you will be happy with the increased fuel mileage and performance it brings ya I will gladly help you with any of the wiring issues you might run into, now with that said your system is OBDII and I am OBD1. Which wiring wise I dont think is all that different other that you have one extra O2 sensor than I do. wiring into my jeep was simple once i undertood how it all worked. It really only needed like five wires to run. then it was a matter of hooking up gauges as long as you label everything when you remove the old motor it will be simple. I do recomend getting a good service manual for the vehicle your motor came out of and start studying those schematics. Good luck brotha!! and welcome to the club
my 5.2 swap starts here on post #309
http://www.jeepforum.com/forum/f22/s...6/index21.html
build thread:
skyj is offline
post #9 of 75 Old 02-06-2014, 08:52 AM Thread Starter
JCashen
Private sell from craigslist. My grandpa and I talked to him for awhile before purchasing it and he seemed like a good guy not to say there aren't smooth talkers out there.
It'll be a few months before I have everything to start the swap but the guy said if I drive it up to where he works (which is where we picked it up from) he will do 90 days from that point.
"Drippy"
JCashen is offline
post #10 of 75 Old 02-06-2014, 09:56 AM
bmgadg
Nice motor, I've got the same one in my rig. Mine's a 96 that was originally OBDII, but I converted it to OBDI with just a few parts swapped out. Good luck with your swap, it'll all be worth it in the end!
bmgadg is offline
post #11 of 75 Old 02-06-2014, 11:03 AM
Xpress
Fuel injection has so many advantages over carbureted that you'd be an imbecile to go back to a carb on a FI engine. Your 'guy' may be old school, but that particular engine is not. I'm not 100% familiar with the ignition systems on that engine, but I'd imagine swapping to a carb means replacing the dizzy and a few other components just to get it to work right. Stay with the times, don't go back to the stone (carb) age
Stick with it. OBDII is a bit more complicated, but only because there is more to it. Time is all it will take, and a little trial and error. In the end, you will have a more reliable engine setup.
FI is a dynamic system. It is always changing A/F mixtures so that the engine runs at an optimal efficiency range, regardless of altitude, air temperature, incline, etc. All of which can bring a carb setup to its knees.
All about that unibody life.
Xpress is offline
post #12 of 75 Old 03-04-2014, 05:33 PM
skyj
Hey Jcashen my stuipid account wont let me open or read any pm's from you nor can I send them. Glad you got it running bud!!
build thread:
skyj is offline
post #13 of 75 Old 03-06-2014, 03:27 AM
SunDevilJeeper
Welcome to the Magnum club!
And much like Xpress said, just stick with FI. These are Magnum engines, not the old LA 318 and 360 engines. It wouldn't make much sense to reverse engineer a fuel injected engine back to its older brethren that Chrysler has since moved on from.
Personally, I'd rather deal with the wiring and electronics headache for a week at most while doing the swap, than deal with a lifetime of dickin' around with a carburetor every few days.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #14 of 75 Old 03-06-2014, 07:10 AM Thread Starter
JCashen
Skyj - maybe I'm not cool enough?
On a side note I'm very excited I got it started. Wiring wasn't even that bad. 2 days to strip what I didn't need then 2 days of messing with it to get it started.
I just want to go out there and listen to it run!
I have to go to a monthly function to run the IST with the rest of the pool on Saturday then I'll be going to my uncles to borrow his cherry picker.
I still have little things to do over the week but I'm hoping I can get it done.
"Drippy"
JCashen is offline
post #15 of 75 Old 03-06-2014, 08:07 AM
Plato2k5
Efi or you will hate life when you go offroad. Holley truck avengers are good, but everyone I run with who has them still have issues running rich and sputtering.
Look up megasquirt Efi. Standalone ecu you link your laptop up to and you can change your fuel and afr maps. Plus a ton more.
Plato2k5 is offline
