5.9 magnum v8 swap? - JeepForum.com
post #1 of 10 Old 06-06-2012, 09:48 PM Thread Starter
NW4wheeler
5.9 magnum v8 swap?
So the 4.0 in the yj has well over 400k miles on it now and im starting to see that it wont last much longer its been a great engine but now its time for something new. Ive been interested in doing a 5.9 magnum swap either from a zj or a dodge and am woundering if you guys could find me some info on the subject. I would like to keep it a 5speed. if you guys could help that would be greatly appriciated. Thanks again guys. oh and i wouldn't mind seeing some videos if you have any links not to much on youtube.
NW4wheeler is offline
post #2 of 10 Old 06-06-2012, 10:26 PM
scubamc
Sure we will do all the searching for you. Just click here.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 10 Old 06-07-2012, 07:59 PM
1SASjeepster
Check out NOVAK JEEP CONVERSIONS. All they specialize is in jeeps and their website has a lot of free information and how to do it.
Take care,
Check out "YJ V6 Conversion" if you want to see a frame up restoration of my 1992 YJ.
Check out "WWII Jeep Photos AND Restoration of..." if you want to see the original JEEP in action...
1SASjeepster is offline
post #4 of 10 Old 06-08-2012, 10:37 AM
bmgadg
Take a look at my build thread.
bmgadg is offline
post #5 of 10 Old 06-08-2012, 11:25 AM
remmons
Search is your best friend. You won't learn much anything if you don't do the research yourself.
Robert.
remmons is offline
post #6 of 10 Old 06-08-2012, 01:27 PM
czjeeper
There are several threads covering this swap that many of us have done.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #7 of 10 Old 06-08-2012, 02:15 PM
Rynfw100
bmgadg's thread and Moparfreak's thread are two of the most helpful information buckets about this particular swap. The 5.2L and the 5.9L are pretty similar swaps, so those are the two best to follow. Mine's a humogumbo mess, but I can find you any part or part number that you need if you need it... cause I did document those.
Good luck in your research
My 5.2L V8 swap and Jeep build:
http://www.jeepforum.com/forum/f12/1993-2-5l-jeep-wrangler-build-5-2l-swap-1210512
Rynfw100 is offline
post #8 of 10 Old 06-05-2013, 07:51 AM Thread Starter
NW4wheeler
So I bought my 5.9 today $400 for the motor with 148k wireing harnes computer and all bolt on acc like ac alternator ext. So ho much of the wireing harness is actually used? How did you guys go about spliceing into the 5.9 harness? I'm still trying to find a dodge dakota bell housing seems the are kinda rare. And since I'm using a 93 ax15 that has a vss don't I have to get a computer from a dakota mt v8 but that had the nv3500 I don't know what computer to use.
post #9 of 10 Old 06-05-2013, 10:47 AM
Jones-Maryland
If you are only looking for a V8 dakota bellhousing the V6 magnum w/AX15 bellhousing is the same, this might help you at the junk yard. I know I have one. I was colleting for this swap but have since changed direction.
Jones-Maryland is offline
post #10 of 10 Old 06-05-2013, 02:15 PM Thread Starter
NW4wheeler
didn't the v8 dakota come with an nv3500 instead of the ax15? Thought the 4 and v6 was ax15. Or is the nv3500 bell housing the same as the ax15.
My 5.9l Magnum Swap SGjeeper36 TJ Wrangler Technical Forum 21 03-11-2015 08:50 AM
Swap a 3.9 magnum into the yj Russell_Goodall YJ Wrangler Technical Forum 18 10-28-2011 07:30 PM
5.2L Magnum Swap - What's needed? Rynfw100 YJ Wrangler Technical Forum 26 05-06-2011 08:30 AM
5.2 Magnum swap question czjeeper YJ Wrangler Technical Forum 0 10-10-2010 10:31 PM
Looking into 4.2 to 318 (5.2) Magnum Swap lt_liverdamage YJ Wrangler Technical Forum 6 01-11-2010 10:35 AM
