5.3 into 89 4.2 Need Wiring Advice and Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 5.3 into 89 4.2 Need Wiring Advice and Help
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 08-25-2015, 01:09 PM   #1
zrides
I had my harness modified by 150tunes.com and I just need to know on my Jeep where to get the ignition + from, and I also have a purple wire that indicates starter solenoid, do I wire that to the key, or the factor start relay?
Any additional wiring help would be appreciated.
zrides is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 03:28 PM   #2
Randonexplosion
Randonexplosion's Avatar
Not sure exactly what they did to your harness but this should help you. That's what I used to get fuel pump signal to (from) the PCM, crank signal to the starter, ignition power etc.
5.3/4 link build
2016 Moab Trip
Randonexplosion is offline   Reply With Quote Quick reply to this message
Unread 08-25-2015, 03:43 PM   #3
Randonexplosion
Dont forget about adding a fuel pump relay and wiring in a relay to your brake switch for the torque converter unlock (if you are running the 4l60e)
5.3/4 link build
2016 Moab Trip
Unread 08-26-2015, 02:47 PM   #4
zrides
Randonexplosion:
Thank you, I appreciate the info. So for the ignition switch you just hooked up your harness starter solenoid wire to D5? Which I am assuming is straight from the key?
Brake Switch I have to install a relay to switch it from ground to power, as the computer wants power signal and my factory brake switch is just a grounding switch correct?
Thanks
Josh
Unread 08-26-2015, 04:43 PM   #5
Randonexplosion
Here is where I address the wiring in my build http://www.jeepforum.com/forum/f22/y...3/index24.html
I was pretty clueless so if I can do it, you can
This addresses the torque converter wiring http://www.jaguarspecialties.com/tech_tips5.asp
5.3/4 link build
2016 Moab Trip
