5.2L Magnum Swap - What's needed? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 5.2L Magnum Swap - What's needed?
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 04-24-2011, 11:54 PM   #1
Rynfw100
Hi there,
So I'm considering of doing an engine swap of a 5.2L Magnum engine into my 93 Jeep with 4 angry squirrels. I want to start collecting parts, and I've comprised a mental list so far, but I do have a couple of questions on parts and certain aspects of the modifications.
I plan on getting a 5.2L from either a Dodge Dakota, or Grand Cherokee. First question being what years have the MPFI? I want to use an AX-15, so I can keep my NP231J. I'll get the 23 spline input shaft, and a Dodge Dakota Bell-house to link the transmission to the engine (I believe?). I will get the Wiring harness and Computer with the engine, and Motor Mounts/Headers from Novak.
So here's the section on the couple of questions I have. Will the AX-15 need new Transmission mounts welded on? Next, Will the 92-96 Dakota Bellhousing link the Transmission to the Engine directly?
Here's a parts list, correct me if I missed anything?
-5.2L Magnum Engine
-ECU from Engine
-Wiring Harness
-Novak Motor Mounts
-Close-to-Block Headers
-92 to 96 Dodge Dakota Bell housing
-23 input spline for NP231J
-Longer/Shorter Drive Shafts
-Possibly New Radiator
I appreciate any help on the subject, Thanks in advanced
Rynfw100 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 12:55 AM   #2
bracs4
im doing this also excpt my 318 is carbed already so shoule be bolt wire and go in its simpleest form
bracs4 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 10:03 AM   #3
Rynfw100
I thought about that, however I had too many problems with my past vehicles that were carbed. I like the OBD-1 engines with either TBI or MPFI, cause they're just easier to work on.
What transmission are you using for this swap?
Unread 04-25-2011, 10:51 AM   #4
Fuddmaster
I'm in the process of doing research for this swap but I want. Different tranny? Keep is posted
Fuddmaster is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 10:55 AM   #5
theducksguts
Your AX-5 isn't going to last behind a 5.2L. Make the upgrade to an AX-15 or NV3550.
If you use an electric fan and mod the headers then you can move the engine back 1.5 inches or so towards the firewall allowing you to use your stock drive shafts. Otherwise you will need custom length shafts.
You are going to need a new radiator.
Backwoods offroad has a lot of information about the swap. I am planning a 5.9L swap on my TJ in the next few years.
00 XJ Sport 0331 Victim
99 XJ Sport
98 TJ
Check out my Classifieds
theducksguts is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 10:56 AM   #6
sbsg2005
I'm using one from from a 1992 dodge truck for this swap and a 727 trans. I believe 92 was the first year for smpfi.
sbsg2005 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 05:03 PM   #7
Rynfw100
I planned on going with the AX-15, I hear that the NV3550 is quite noisy. Also, I'd rather just modify the NP231J from 21 spline to 23 Spline, while doing a SYE for this swap.
What do you mean by modding the headers?
Unread 04-25-2011, 06:06 PM   #8
theducksguts
Depending on where you get your engine from (you said yours is from a Dakota) the headers, may or may not allow you to move your engine back further towards the firewall.
I have heard that Durango headers work better for swap in to a SWB Jeep but have only read this and haven't performed the swap yet. I am trying to learn as much as I can about a 5.9 swap before doing it. Especially stuff about the wiring and programing the PCM.
AX-15 should hold up fine.
99 XJ Sport
98 TJ
Unread 04-25-2011, 07:21 PM   #9
bracs4
well ive decided to big or go home im going to the 5.9
Unread 04-25-2011, 08:47 PM   #10
Rynfw100
There you go. Now the fun part begins, collecting parts
Unread 04-25-2011, 09:31 PM   #11
stoveguy01
exhaust manifolds from a grand cherokee work very well and will allow you to move the engine back 3 inchs leaving lots of room for stock fan from 5.2/5.9
stoveguy01 is offline   Reply With Quote Quick reply to this message
Unread 04-25-2011, 09:54 PM   #12
Rynfw100
Thank you Sir. I will look into that. My biggest concern besides the exhaust, which you just helped alot with, is Getting the 5.2L to mate to the AX-15. Should be tons of fun
Unread 04-25-2011, 10:03 PM   #13
stoveguy01
well if your dead set on staying with the ax15. easiest way is to find a bell housing from a dodge dakota. dont remember the years but the ax15 was used in them behind both the 3.9 v6 and the 5.2. I converted mine to an auto at the same time
Unread 04-25-2011, 11:02 PM   #14
bracs4
its from 92 to 96 v6 dakotas my 5.9 is set up for fuel injection anyone know how to det uo fi on a car meant for carb because the kit from edelbrock to convert the engine to carb with a carb is close to 600
Unread 04-26-2011, 01:37 PM   #15
bmgadg
Props on keeping it in the Mopar family! Check out my build thread for the answers to some of your questions. Anything else you need help with just ask.
You'll love the 5.9!
My v8 YJ Build Thread
bmgadg is offline   Reply With Quote Quick reply to this message
