5.2 swap has begun - Page 6 - JeepForum.com
post #76 of 99 Old 11-01-2012, 07:08 AM
mylilyj
Food for thought. I put a 6pinion planetary and wide chain when i redid tcase. Couple days in junkyard tearing up tcases. But the experience was great. As I am just a hobbiest and not a pro mechanic.
on facebook
mylilyj is offline
post #77 of 99 Old 11-01-2012, 07:33 AM
SunDevilJeeper
Originally Posted by mylilyj View Post
I used 46rh from donor zj. I used a radiator I picked up for bout 200. It had the inlet and outlet on correct sides and was 3core compared to stock 2core. Then put Taurus elective fan. I moved motor as far forward as possible. I still had to get super short sye and drill my center pin on spring perch 2 inches back and ended up with 17.5 inch driveshaft. I also welded some 1/4 inch plate to rear of skid cause tcase stuck out past rear of skid. I made my own frame side motor mounts and used the pick up truck mounts on motor side. Beefier. And i didn't like the mounts in front on the zj mounts.
Sounds like one long *** drivetrain for a Wrangler! What's the length of the 46rh? The AX15 only has a couple more inches over the AX5 if memory serves me right. Which contributes to my mount/shifter location problem I'm betting.
1991 YJ: Daily Driver
1992 YJ: Pile of crap sitting in the garage.
SunDevilJeeper is offline
post #78 of 99 Old 11-01-2012, 09:50 AM Thread Starter
stoveguy01
both mine and my wifes jeep I used the mega short sye set up on my yj I actually had to lengthin my rear driveline over what it was with the 6cyl ax15 and I moved the tcase back 4 inches.
US ARMY COMBAT VET
MODIFY, ADAPT, & OVERCOME
stoveguy01 is offline
post #79 of 99 Old 11-02-2012, 01:36 PM
SunDevilJeeper
Yeah I'm lookin at the JB conversion kit, then I started looking at the teralow 4:1 kit and all that. The JB kit makes the 231 shorter than an Atlas II which is a plus.
post #80 of 99 Old 11-02-2012, 02:20 PM
mylilyj
Jb had a waiting list and after 8weeks I couldnt wait any longer. The Terra version. Is just as short. FYI.
on facebook
mylilyj is offline
post #81 of 99 Old 11-04-2012, 07:49 AM
SunDevilJeeper
How long ago was that? After looking at their selling points, I'm pretty sold on the JB.
post #82 of 99 Old 11-04-2012, 08:07 AM
mylilyj
I was all about it too, being made in USA and all. It was summer of '10. My bud had to wait as well in '09. It's a small shop and they only order material when they run out. At least that's what they told me. They did eventualy call me though but I had been driving my rig for a month by then.
on facebook
mylilyj is offline
post #83 of 99 Old 11-04-2012, 08:41 AM
SunDevilJeeper
Damn wtf? One would think that you order more **** BEFORE you run out!
I'll call them first before I place an order to make sure I don't have to go through the hassle of cancelling my order. I don't feel like putting up with the same **** that a lot of people went through with Superior, which by the way I'm gonna put in a call beforehand as well when the 8.8 is done.
post #84 of 99 Old 11-04-2012, 09:25 AM
mylilyj
If you looking for 8.8 . Check Yukon out. They have c clip eliminator and grizzly. Great products that they stand behind their warrantees.
on facebook
mylilyj is offline
post #85 of 99 Old 11-04-2012, 09:29 AM
SunDevilJeeper
I was hearing something about Yukon having those as well, does it stretch the track width out like the Superior kit?
post #86 of 99 Old 11-04-2012, 10:25 AM
mylilyj
Yes sir.
http://www.pirate4x4.com/forum/axles...5-5x5-5-a.html
on facebook
mylilyj is offline
post #87 of 99 Old 11-04-2012, 10:30 AM
SunDevilJeeper
Hot ****! Might as well go with that since I'm gonna be going with Yukon 4.88s as well! Thanks for that bit of info!
post #88 of 99 Old 11-04-2012, 10:33 AM
mylilyj
Green country offroad sponsored me a hp44 cut down to tj rubi inners housing. He threw in Yukon chromo inner and outer for up front. He also threw in 1541 Yukon for my 8.8. I used spider trax bp adapters to match 5x5.5. Yukon sponsored me a grizzly for the 8.8. I am gonna run this till I break it. Then I will go with yukon c clip eliminator that comes with chromo shaft. That's if i break it.
I launched my yj off a double bump and ripped my driveshaft in half. The 1541s held up. I will link my HP44 and grizzly thread for ya if intereasted.
on facebook
mylilyj is offline
post #89 of 99 Old 11-04-2012, 10:37 AM
mylilyj
http://www.pirate4x4.com/forum/jeep-...ld-thread.html
on facebook
mylilyj is offline
post #90 of 99 Old 11-04-2012, 10:37 AM
mylilyj
http://www.pirate4x4.com/forum/jeep-...zly-8-8-a.html
on facebook
mylilyj is offline
count down for 5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 2 03-11-2010 10:46 PM
The rebirth has begun RallyeX Wrangler General Discussion 10 08-02-2009 12:39 AM
4.3 install has begun 2cjs YJ Wrangler Technical Forum 10 05-25-2007 11:01 AM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 01:33 PM
Modding has begun 06WranglerX TJ Wrangler Technical Forum 4 05-10-2006 08:10 PM
