5.2 swap has begun - Page 3 - JeepForum.com
post #31 of 99 Old 03-22-2010, 11:46 PM
kevings
Junior Member
kevings's Avatar
im jealous!!!!!
enjoy
kevings is offline
post #32 of 99 Old 03-23-2010, 12:02 AM Thread Starter
stoveguy01
im lovin it got quit a few double takes driving around today. and getting up to speed and merging on the freeway not a problem any more
stoveguy01 is offline
post #33 of 99 Old 03-23-2010, 12:10 AM Thread Starter
stoveguy01
the key is planing think everything thru a dozen times before starting. have a plan and stick to it. have everything preassymbled that is possible and its possiible to do this in a weekend. mines proof.
post #34 of 99 Old 03-26-2010, 05:59 PM
MoparFreak69
Looks nice sitting in there. I wish I had a few extra $$ laying around to get mine done. I bet that thing merges on the freeway effortlessly now lol. Great job on the swap! Got any pics of the rear driveline and the trans mount/belly pan so I can get an idea of what i'm up against there?
MoparFreak69 is offline
post #35 of 99 Old 04-17-2010, 10:21 AM Thread Starter
stoveguy01
update
well just thought id update this. Its been a few weeks since I done this swap and Im happy to report absolutely NO problems. its like Ive got a new jeep the power is everything I was hoping for it runs amazing and I definetly recomend this swap.
post #36 of 99 Old 04-19-2010, 08:12 PM
mark12010
What tranny and transfer case did you use. Do you have any pics of the way you fabed up the tranny mount? Looks awsome by the way.
mark12010 is offline
post #37 of 99 Old 04-19-2010, 08:57 PM Thread Starter
stoveguy01
I used a 46rh auto that came with the engine from a 94 grand cherokee and reused my 231 t case, I dont have pics of the mount but will take some. basicly tho I used the plate thats came on the trany and welded a strip of 1/2 c chanel and some scram 1.4 in plate I had to move it back and give me clearance than drilled the plate for stock mount
post #38 of 99 Old 04-21-2010, 12:04 AM
moparcory617
Nice build I have actually started the same swap for my 90 yj I have looked all over for info in doing this, i pulled the 4.0 that some one else swapped in it this past weekend i plan on running the 318 727 with my 231 behind it. and or i have a 241 and i will be streching the rear at least 6 inchs so thanks for the pics it has me less worried about will it fit right I will probably have some questions along the way,lol glad you went mopar!
moparcory617 is offline
post #39 of 99 Old 04-21-2010, 07:41 AM Thread Starter
stoveguy01
Ill try to take pics of the mount today life has been crazy this week. So moparcory, are you going fuel injection?
post #40 of 99 Old 04-21-2010, 08:01 AM
mark12010
I think since the motor has no intake and was never fuel injected I am going to go with a good intake and new 4 brl Carb to keep it simple.
Excuse my ignorance but what is "scram"
post #41 of 99 Old 04-21-2010, 08:41 AM Thread Starter
stoveguy01
id at least do a tb set up can be done with wrecking yard parts for cheap youll be much happier just my .02 cents worth. I HATE carbs lol
post #42 of 99 Old 04-21-2010, 10:33 AM
mark12010
The NP231 will not bolt up to the 727 without an adapter at least thats what I was told can anyone confirm or deny this.
post #43 of 99 Old 04-21-2010, 08:18 PM
moparcory617
no stove guy I will be going with carb Less wires,lol I have a friend that hooked me up with a propane kit so I decided I would go that route, Its cheaper all the way around and I plan on rolling it at least once so I dont want to much tied up in it. and mark as far as I know it will all bolt up same spline count same mounting holes and from the ones i have talked to said it will bolt right up
post #44 of 99 Old 04-21-2010, 08:27 PM
moparcory617
ok mark i was wrong it will not bolt up you are right the 231 is 23 spline my 727 in 27 spline so i will be going 241 thanks mark i have been informed wrong lol so does that confrom it,lol
post #45 of 99 Old 04-22-2010, 09:41 AM
mark12010
Any progress on the pics of the tranny mount?
count down for 5.2 swap has begun stoveguy01 YJ Wrangler Technical Forum 2 03-11-2010 10:46 PM
The rebirth has begun RallyeX Wrangler General Discussion 10 08-02-2009 12:39 AM
4.3 install has begun 2cjs YJ Wrangler Technical Forum 10 05-25-2007 11:01 AM
It has begun... Yet another swap thread. sauce90yj YJ Wrangler Technical Forum 38 04-24-2007 01:33 PM
Modding has begun 06WranglerX TJ Wrangler Technical Forum 4 05-10-2006 08:10 PM
