5.2 into wrangler - JeepForum.com
post #1 of 10 Old 11-09-2013, 10:31 PM Thread Starter
WillieD
5.2 into wrangler
Hey,
I have an 88 YJ with an 4.2 in it and thought I had bad lifters and cam. When taking head off that doesn't look like the problem. I can either rebuild this motor again or I currently have a ramcharger with a 318 I could swap in. Not sure what route to go. Will listen to any suggestions. Thanks
WillieD is offline
post #2 of 10 Old 11-09-2013, 11:18 PM
Xpress
Easiest method would be to rebuild the 4.2L. Going with FI makes the engine perform even better than the carb.
A V8 swap is a very involved process.
All about that unibody life.
Xpress is offline
post #3 of 10 Old 11-10-2013, 12:08 PM
88_yj
88_yj's Avatar
The v8 would be nice but complicated getting the fuel injection working. If you went with a carb 318 it's just motor mounts exhaust and changing the bellhousing to one out of a Dakota with ax15
Sent from AutoGuide.com Free App
88_yj is offline
post #4 of 10 Old 11-11-2013, 04:57 AM
Jeepsr4me
having the donor vehicle and in running shape is really nice. Cause most folks start with a engine that is already out and with out all the wires and hoses and fuel pump to run it. The run around rewiring every thing under the hood of jeep or buy a harness. Where you can take whole harness from ram IF its EFI,
Jeepsr4me is offline
post #5 of 10 Old 11-14-2013, 07:42 PM
mike_breaker_5
the v-8 swap isn't that hard, like 88_yj said the wiring can be a pain.
having said that ... there are a couple guys here on the forum that have done it quite successfully. i am a wiring retard so i had someone else wire it up. i think sun devil jeeper and mopar freak both wired up their own 5.2's
however... if i had it to do all over again... i would have gotten an older 350 bowtie and bought the summit efi standalone kit. i would have had exactly the same amount of cash in it and i could have done it myself. the chevy 4500 trans is a little easier to find than the dodge gasser 4500 trans.on top of that, there is a lot more aftermarket for chevy motors than the 5.2 magnum.
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #6 of 10 Old 11-14-2013, 09:09 PM
czjeeper
The Ramcharger is a carbed 318, not the Magnum 5.2.
My opinion is, it's not worth the trouble w/out EFI.
It's really not that hard to wire in an OBD 1 5.2/5.9.
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #7 of 10 Old 11-14-2013, 09:10 PM
richh789
1987 YJ Wrangler
I have a 5.9 outa Durango rt. Use the entire Durango harness. Used duRango column and gauge cluster. Everything works perfectly, the only two issues I have is that the speedometer doesn't work, as the rear is a sterling , and when you turn the directionals on they blink fast as if a bulb was out. and the airbag light is on
richh789 is offline
post #8 of 10 Old 11-15-2013, 07:56 AM Thread Starter
WillieD
318 out of Ramcharger doesn't have a carb. Uses throttle body and the jeep it be going in uses a carb.
WillieD is offline
post #9 of 10 Old 11-15-2013, 08:28 AM
Hoxie
Hoxie's Avatar
1987 YJ Wrangler
I'd just swap in the V8 but maybe I'm just biased. Iv never done engine work or anything like it. Been doing mine with the help of JF.
YJOTM January 2017
Hoxie is offline
post #10 of 10 Old 11-15-2013, 09:29 AM
Xpress
[QUOTE=richh789;17718625]when you turn the directionals on they blink fast as if a bulb was out/QUOTE]
You need to either use higher wattage turn signal bulbs, or switch to an electronic flasher relay...
Xpress is offline
