5.2 clutch install - JeepForum.com
post #1 of 2 Old 09-06-2011, 06:30 PM Thread Starter
czjeeper
5.2 clutch install
I got my 11" clutch today, spec'd it for a '94 Dakota.
I resurfaced my 5.2 flywheel at school.
I dropped the disc and cover on the flywheel to match it up and try to figure out which bolts I need to attach the clutch to the flywheel.
the flexplate doesn't touch the flywheel it sits up about a 1/4". Is that a problem? The FSM says to tighten 2 threads at a time in a criss-cross pattern to avoid warping the cover.
Also, anybody know how long the bolts bolts are? The ones I'm using look to be a bit too long and will stick out the other side of the flywheel. How far out can they protrude?
US Army combat vet
2011 Grand Cherokee Laredo 3.6
Armed Forces Jeeps Member #125
Red Jeep Club Member #251
In the Portland/Vancouver area? Check 'em out!
czjeeper is offline
post #2 of 2 Old 09-07-2011, 01:30 PM
bmgadg
The clutch disc will be sandwiched between the cover and the flywheel, and you'll tighten the cover bolts down to spec, seems like 40lbft. That's about all I remember when I did my clutch.
I wouldn't have the bolts sticking out the back of the flywheel, seems like that wouldn't be good.
bmgadg is offline
LUK Clutch Kit install help reisom TJ Wrangler Technical Forum 15 03-10-2011 12:23 AM
Clutch Install tjjack TJ Wrangler Technical Forum 10 03-07-2011 01:08 AM
88 5 Speed - Tranny Not Engaging After Clutch install (no clutch need to shift) kgillette YJ Wrangler Technical Forum 12 11-01-2009 12:39 PM
Soft Clutch after clutch install..... scottsea YJ Wrangler Technical Forum 5 10-23-2009 11:11 AM
new AX-15 install w new clutch kit dadthemechanic YJ Wrangler Technical Forum 3 07-12-2009 12:57 PM
