#91 | |
http://i24.photobucket.com/albums/c16/Stang5lgt/Captured2000-1-1800000.jpg
I will get some more pics for you guys.
For Off Road Deployment |
#92 |
http://i24.photobucket.com/albums/c16/Stang5lgt/Captured2005-12-1800002.jpg
http://i24.photobucket.com/albums/c16/Stang5lgt/Captured2005-12-1800003.jpg http://i24.photobucket.com/albums/c16/Stang5lgt/Captured2005-12-1800004.jpg http://i24.photobucket.com/albums/c16/Stang5lgt/Captured2005-12-1800005.jpg Here are some more pics. Some of the slave set up too.
#93 | |
'95 Mustang GT '91 YJ 4.0L /l ,[____], l---L--?lllllll?- ()_) ()_)----)_) White Jeep club member #40 |
#94 |
Just added another pony to my stable...
Comes packed with one of these.... http://www.photodump.com/viewer/the5barrons/350CHEVY2.html I'm stoked. 94 YJ, 35's, 350 chevy, 3 speed auto, blah blah blah. Got some work to do...like eliminating the 3" body lift and upping the leave to 4.5+.... Oh boy does it have power..... Sticks Your install looks to be going great....your going to love it.
1993 YJ | 2.5L 4 banger | 3.5" Superlift | 1" BL | 4.88's | 33" BFG's | 2007 Toyota Tundra Crew-max | 4x2 | 5.7L | Truxedo Tonneau | 20"'s | Leather | Fully debadged 1999 XJ | stock | 4.0 |
#95 | |
#96 |
How did you figure out the wiring so fast, im dreading the day I have to start wiring the chevy 350 into my jeep, and I have yet to find real good info on it. I was thinking of buying a universal wiring harness, my friend can get me one for $150, so price isnt bad, but how did you do it?
and o yeah, what do you think is the best way to get those novak motor mounts all lined up and square? I have the same ones and have been debating the easiest way to get them in there straight, level and square.
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project Interned at Novak Conversions 2 summers ago Last edited by youngjeeper11; 12-18-2005 at 10:29 AM.. |
#97 | |
It also helps since Ford is like ten times easier to wire the Bowtie. That is why so many people tune Mustang 5.0 there is nothing to them. The motor mounts I bolted the motor to the tranny then I took protractor and set front of the motor so it was up 5 degrees. Once I got it set I bolted the mounts on. Took magic marker and marked around the mount on the frame. Then took the motor out. Leveled the mounts with my marks welded. Then put the motor back in. It was easy.
#98 | |
#99 |
yeah, thats what I was thinking of doing with the motor mounts, except I was going to get it all set, then tack the frame mounts, pull the engine out, then finish welding them. thanks for the help
Jeep 1:Used to have a 93 YJ 2.5l- 3.5" Black Diamond, Chevy TBI 5.7l V8, SM 465 4 speed, 8.8 rear( 4.10, L/S), rhinoline, Mile Marker 9000, NP 231, Had to sell it due to college Jeep 2: 89/91 YJ, 4BT Cummins, NV4500, NP 231, Old Man Emu 2.5" suspension lift, 1" body lift.....Runs and drives, but very much a project Interned at Novak Conversions 2 summers ago |
#100 |
Im in the middle of putting a 5.0 in my YJ also. I put a C6 tranny behind it. im also running 2 transfercases a 203 and a dana 300... the swap is going pretty well im still trying to figure out some of the wiring because it idles at 4,000 RPM...
under construction: 94 YJ 5.0-C6-203-300, dana 60, 14 bolt, 4.10's, Welded, 44's, Full Hydro, 1410's in drive shafts. |
#101 | |
#102 |
I went to the bone yard and got a set of manifolds and Y pipe out of 89 F150. They fit. So I think she will be ready to drive this weekend. Merry Christmas to me.
#103 |
Down to the 4th page and no new information? Methinks you need to get back to work
Merry Xmas |
#104 | |
i am a HUGE Ford fan as well... i am in tha same boat with having all Fords other than my YJ.....and my Dad's TJ
1992 YJ Sport White 4.3 swap in progress Eagle Scout Jeep Owner |
#105 | |
It's been nice weather too. Well I bought the upper radiator hose had to get a flex one. I had some other parts I had taken off the motor for one of my mustang so I have been looking for those. I was trying to replace the studs on the exhuast manifolds and one of the manifold broke. So I had to JB weld it. I hope it holds. The other problem is my wife gave me my Christmas present early so I have been playing GUN on the Xbox last two days. I might try work on it today some. And maybe tomorrow. If I work on it tomorrow. I should have it going. Only thing I need to do get it started is hook up the inline fuel pump.
