#16 | |
http://www.novak-adapt.com/knowledge/fsb_swap_yj_87-95.htm
This is a place I found some info. Since Advance Adapters web site sucks. But they have all the parts needed.
For Off Road Deployment |
#17 |
My biggest worry is the extra weight might make the front end sit lower than desired. I'm wanting to do a RE 4.5" lift, 302H.O, winch, and maybe later on a hard-top and full doors. Does anyone know if the springs will still keep the Jeep level after this?
2000 Jeep Wrangler 4.0 | 4" Superlift, 33x12.50 BFG Mud Terrains, 4WDHW Rear Bumper OTHER RIDES: 1993 Mazda RX7(HBP, T04R), 1999 Honda Civic Si(AutoX/DD Car), 1975 & 1977 Honda GL1000 |
#18 |
They say the 5.0 is only about 100lbs more the 4.0. I will post pics when I have it done.
#19 |
http://i24.photobucket.com/albums/c16/Stang5lgt/Captured2005-12-200003.jpg
Got the motor mounts welded in. Now I have get a 11 inch clutch disc from Chevy truck with 10 teeth and 1 1/8 shaft. Pressure plate and throw out bearing for 87 F150. Then I can bolt the motor in. All smoke is in the pic is from welding.
#20 |
I put a winch on the front of my Jeep and I noticed a difference while driving. I felt the weight in the front. You may have to play with the suspension some, but I think the motor by itself wouldn't be too bad seeing as the weight difference is only 100 pounds and it's not on the edge of the Jeep.
#21 | |
King of Mac-istan
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen. -Samual Adams A government big enough to give you everything you want is big enough to take everything you have. Thomas Jefferson Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists" Nemo Me Impune Lacessit "No one provokes (attacks) me with impunity". "Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..." Mac Wilson |
#22 |
I am a Blue Oval nut Myself it is all i will own other than my YJ I want to install a 302 into mine also I waould love to get all the details from you what u used tranny and stuff. I have had 8 Mustangs with the 302 ho. Thanks.
60th Anniversary TJ RE BB Lift Moabs and MTRS Rubi Rock Sliders FUTURE MODS: Axles Lockers |
#23 |
Here is my part list so far.
5.0L HO motor, ECM, and wiring out a 90 Lincoln LSC Bellhousing, slave cylinder, starter, and start shim plate of a 87 F150. Flywheel for a 5.0 F150 11 inch 10Tx1 1/8" clutch disc for 88 Chevy 1500 305 motor. Throw out bearing and pressure plate for 87 F150. Motor mounts from Advanced adapter. AX15 to Ford small block adapter plate this lets you bolt a Ford truck bellhousing to the AX15. AdvanceAdapters.com has part #s Use those part numbers and buy them from Summit Racing they were 80 bucks cheaper then Advance for there adapters. If I was going to do it again I would build my own motor mounts. Could have saved 100 bucks. I have inline fuel pump and bracket out of Econoline Ford Van I found at the Bone Yard. Only things I have get now is Headers. I will post when I find some. I read that the 5.0 weighed about the same. But I also read Chevy was heavier then 4.0. So I figured I would be safe by saying 100lbs heavier.
#24 | |
'95 Mustang GT '91 YJ 4.0L /l ,[____], l---L--?lllllll?- ()_) ()_)----)_) White Jeep club member #40 |
#25 | |
#26 |
I have 5.0 emblem off the side of my Mustang might just stick on the back of the YJ.
#27 | |
post a pic of it if you do that. the guys on the mustang forums i post on would love to see that!!!
#28 |
Wife put project on stand by. So hopefully I can get a clutch by weeks end.
#29 |
Hey thanks this list will get me started only thing i see being a problem is i am replacing a 4 CYL so i think i will have to buy a new tranny. keep the post coming Thanks,
#30 |
Advance Adapters AX15 to Ford adapter looks like this:
Greg |
