4XRAC system on hood - JeepForum.com
post #1 of 2 Old 11-30-2011, 12:46 PM Thread Starter
RSC17
Has anyone used the 4XRAC system to mount their HiLift on the hood? I was wondering where would be the best placement on the hood or cowl would be. Pictures would be a great help.
RSC17 is offline
post #2 of 2 Old 11-30-2011, 02:22 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The hood is probably the worst place to mount a jack. For starters, using it more than once is going to scratch your hood up so badly you'll wish you had left it at home, let alone the weight of it and how awkward it would be to replace it. The folding windshield idea is out the window and so is leaning the hood on the windshield frame. You'll have to use the hood prop and hope that a gust of wind doesn't propel the jack into the drivers seat.
If you're going to use the mounting brackets in a creative yet practical place, run the jack right above the drivers side rear fender flare, right behind the door.
Luck Favours The Prepared
Anticanman is offline
Hood Bug Deflector - Worth it?? Drilling in Hood?? DekX TJ Wrangler Technical Forum 44 11-03-2011 09:16 PM
jeep highline hood info CJ hood on a tj sail78385 Wrangler General Discussion 2 11-08-2010 12:35 AM
Hood prop or lay the hood right back on the windsheild frame? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 27 01-29-2010 04:55 PM
Grill to hood seal- does your hood shake on the hwy? P35A JK Wrangler Technical Forum 7 07-23-2007 08:46 AM
Newb - Hood Latches - hood moves. Hollywood TJ TJ Wrangler Technical Forum 25 03-16-2007 11:04 AM
