4x4 vacuum line problems - JeepForum.com
post #1 of 5 Old 08-10-2011, 12:08 PM Thread Starter
beachedjeepyj
Ok i followed the diagram but i still have problems... Having the "correct setup" the axle stays locked all the time and the 4x4 light stays off. But when i switch the yellow and green lines on the CAD the axle stays unlocked all the time and the 4x4 light stays on.
It seems i have a constant vacuum from the yellow line all the time and none from the green line. It seems i need some help figuring out what is wrong.
Also on the diagram there is black and white figure on the yellow line that goes between the CAD and the T to the black line and indicator switch. What is this?
Originally Posted by Jeep89JV View Post
Do I let others drive my rig? No -- Why, because if this ship sinks i'll be the captain and I go down with this ship.
beachedjeepyj is offline
post #2 of 5 Old 08-10-2011, 12:39 PM
dancytron
This is a better diagram of 1990 and before. For after 1990, your diagram is wrong. Sounds like the green line is bad or the switch on the transfer case is bad.
The "black and white figure" is a check valve.
dancytron is offline
post #3 of 5 Old 08-10-2011, 01:14 PM
c0rnd0g
Are the vacuum check valves just a standard item found in parts stores? I'm going to have to rebuild my vacuum system.
c0rnd0g is offline
post #4 of 5 Old 08-11-2011, 11:52 AM Thread Starter
beachedjeepyj
Ok found out that the switch on the t-case was bad. Replaced it now it works but the 4x4 indicator light is not turning on... the indicator is not bad though, I hooked direct vacuum to it and it turned on.
post #5 of 5 Old 08-11-2011, 07:47 PM
dancytron
Probably a bad line. The lines are more than 20 years old. You probably should replace them all if you want it to be dependable.
What is this? A vacuum line? mweber01 YJ Wrangler Technical Forum 6 10-02-2010 08:31 AM
Vacuum line ID?? Line dragging on the ground.. Gunmetal YJ Wrangler Technical Forum 4 01-21-2010 04:07 PM
Vacuum line problems. Still no air. TheMightyGoat TJ Wrangler Technical Forum 5 08-31-2007 05:55 PM
Front axle vacuum line help (vacuum help part 2) mrmustang YJ Wrangler Technical Forum 13 02-13-2007 06:26 PM
vacuum line problems tonyk YJ Wrangler Technical Forum 6 07-31-2005 01:00 PM
