Quantcast 4x4 POSI-LOCK!(HOME-MADE??) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4x4 POSI-LOCK!(HOME-MADE??)
Brand new! XJ Rear DIY Bumper from JcrOffroad!Spartan Lockers FREE SHIPPING Excellent PricesGR8TOPS Introduces the Exogate HD Tire Carrier
Old 01-26-2003, 12:56 PM   #1
BIG SEXY
HAS anybody replaced the old vacuum shifter fork on the Dana 30 with a cable-activated shifter?
What did you use and brief install comments...
91' YJ,4.0 I-6(180,000 mi) 2" Rancho Add-A-Leaf kit, 1.5" shackle lift, 2" BL, 33x12.50 BFG M/T KM's, 15x8 589's, TJ flares, custom F&R bumpers w/ swing-away spare carrier & rocker guards, FULL ROLL CAGE, herculiner, Warn [B]XD9000i[/B] (IT'S ALSO MY WIFES... or was!!!)
Rig Rater score= 476RRv1.0
Its a dog-eat-dog world. and I'm wearing MILKBONE UNDERWEAR!!
BIG SEXY is offline   Reply With Quote
Old 01-26-2003, 04:27 PM   #2
89YJmoneypit
KMG365
89YJmoneypit's Avatar
I have the posi-lok and it works pretty good.If your good at fabricating it might not be too hard to make one.I think the hardest thing would be making a housing to fit on the axle,all the posi-lok does is reuse your shift fork with a cable and new housing.It was easy to install,messing with the c-clips that hold the fork on was about the hardest part,took me an hour or less to install.If you look Quadratec or J.C.Whitney's site there is a pretty good picture of one.
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
97 ZJ Laredo
4.0, 42re, NP242
Was my daily driver, now son's college partywagon.
89YJmoneypit is offline   Reply With Quote
Old 01-26-2003, 06:39 PM   #3
BamaJeeper
Did I send you a link to a homemade version? I can't remember. Here it is for those interested.
http://www.bc4x4.com/tech/2002/d30shiftmotor/
Out of the darkness comes light.
BamaJeeper is offline   Reply With Quote
Old 01-27-2003, 02:12 AM   #4
Lavacrawler
If you have the $ definitly go with the posi-loc.
I think I saw them on sale at www.windrockoffroad.com
[COLOR=black][B]94 YJ[/B][/COLOR]
[COLOR=darkgreen][B]97 XJ sport[/B][/COLOR]
[B][COLOR="White"]63 cj-5[/COLOR][/B]
[B][COLOR="Red"][URL="http://www.snakeriveroffroaders.com"]www.snakeriveroffroaders.com[/URL][/COLOR][/B]
Lavacrawler is offline   Reply With Quote
Old 01-27-2003, 08:39 AM   #5
southerndawg
I highly recommend the posi-lok as well. Put one on a few months ago after many problems with the vacuum actuated system.
Took me about an hour, and wasn't too much trouble. If you're down there, I would recommend replacing the shift fork as well. Another $10-15, but it's worth it. Haven't had any 4x4 problems since. Good luck.
`95 YJ 4 banger
southerndawg is offline   Reply With Quote
Old 01-27-2003, 08:59 AM   #6
rdnkjeeper
Does this really work??
I was going to do that to mine, but I have been told don't bother.......it doesn't work! Anyone here done it? Does it really work?
Thanks!
It's a Jeep thing and Yes I do Understand!!
rdnkjeeper is offline   Reply With Quote
Old 02-24-2011, 10:27 PM   #7
Drew_CarreyAB
Did this conversion tonight, what a breeze (for me anyways). Used a 3/16 air fitting to mount the cable through the shifter housing, tapped it, threaded it in, fed the plastic wrapped cable in and tightened up. drilled 2 holes in the shift fork and threaded the cable through and back, cut it and bent it back against the fork (that was the hardest part IMO), zip tied the cable to the axle and threaded it through the engine bay. I already had the cable mounted in the cab for my throttle, so I just swapped the purpose of it.
The air fitting seals around the cable tightly enough as not to leak, and for me was free, but if bought would only run like $1-$2, the cable originally cost me $25, and well about an hour of my time.
Drew_CarreyAB is offline   Reply With Quote
Old 02-24-2011, 10:59 PM   #8
Tompatt
1987 YJ Wrangler
this may be the oldest thread revival i have ever seen. haha.
Thomas
-1987 YJ
Jeep Build
Tompatt is offline   Reply With Quote
Old 02-25-2011, 12:03 AM   #9
timatoe
Jello Puddin'
timatoe's Avatar
No doubt, especially when there's a far more current actual write up.
Originally Posted by jbolty View Post
... never underestimate the idiocy of Nancy Pelosi...
timatoe is offline   Reply With Quote
Old 02-25-2011, 10:50 AM   #10
onelow1ton
onelow1ton's Avatar
http://www.jeepforum.com/forum/f12/home-made-posi-lock-write-up-595515/ here is the new thread this one should be locked its so old lol
94 yj 2.5 5 speed s10 bastard packs, 1" booms ,more bushings, high lined fenders, and 33x12.5x15 procomp at's
click the link for my build
http://www.jeepforum.com/forum/f22/my-94-yj-slow-build-aka-moby-dick-1125276/
onelow1ton is offline   Reply With Quote
Old 02-26-2011, 11:45 PM   #11
Drew_CarreyAB
O M G......I didn't realize that I posted 7 years later wow LOL, an update on mine......I think it broke LOL.....gonna rip off the cover sometime and check.....
Glock Forum
