4x4 noises - JeepForum.com
post #1 of 4 Old 05-28-2001, 07:27 PM Thread Starter
dartboy
dartboy's Avatar
4x4 noises
When I engage the 4x4 it makes snapping noises and spits out gear oil over the axle on the drivers side. The 4x4 still works. Any ideas on what teh prob might be.
Thanx,
Jason Duffy
90 YJ/Stock
Jason
90 YJ...Stock for now.
74 Dodge Dart Sport
dartboy is offline
post #2 of 4 Old 05-28-2001, 10:02 PM
wilhelm
dartboy,
is the oil on the front or rear axle ? is the oil coming from the end of the axle or the yoke where the drive shaft is ? the oil is probably a seal and the snapping could be an axle hub bearing ,an axle U-joint or a U-joint on the front driveshaft gone bad . but if it has a locker ,( like a powertrax or lockright ) the snapping is normal .
wilhelm is offline
post #3 of 4 Old 05-29-2001, 09:54 AM Thread Starter
dartboy
dartboy's Avatar
Sorry should have been a little mer clear. The oil is on the front axle. All puddled on the end of the axle where it connects to the wheel. It is coming out hard enough that it is squirting on the tire. I never thought to check the front universals, just changed the rear ones.
Jason
74 Dodge Dart Sport
dartboy is offline
post #4 of 4 Old 06-05-2001, 09:53 PM
wilhelm
dartboy, it sounds like the axle seals are bad , and or too much oil in the differential housing . wilhelm nj
wilhelm is offline
Noises!?! LeeGro TJ Wrangler Technical Forum 7 01-26-2012 12:46 AM
noises oatman98 YJ Wrangler Technical Forum 10 04-19-2007 10:27 PM
Odd Noises baudencm TJ Wrangler Technical Forum 1 04-16-2007 07:27 AM
****ing noises rsm688 TJ Wrangler Technical Forum 10 05-09-2006 03:57 PM
Noises? southdakotatj TJ Wrangler Technical Forum 3 10-09-2004 08:21 AM
