4x4 issue - Page 2 - JeepForum.com
post #16 of 29 Old 05-12-2010, 07:44 PM Thread Starter
Jcowart95
alright i'll try these things out. thanks
Jcowart95 is offline
post #17 of 29 Old 05-13-2010, 04:51 PM Thread Starter
Jcowart95
Yes!
Good news guys I have all four wheels turning. All it took was 6 shots of WD40. There was alot of gunk build up around the linkage and other places on the shifter. Thanks for all your imput.
post #18 of 29 Old 05-13-2010, 05:49 PM
CSCmrwizard
1982 CJ5
if its a dana 300 then you need to see if the pivot is bent or in a bind
if it the 231 it mite have a bad shift frok
have you try to put tran in rev. then shift the tc
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
post #19 of 29 Old 05-13-2010, 08:09 PM Thread Starter
Jcowart95
whats the shift pattern on a trasfer case of a 1995 wrangler? 2H 4H N 4L?
post #20 of 29 Old 05-14-2010, 12:10 AM
dtn8tr
As I stated earlier...yes, that is the shift pattern for a NP231...with 2h being all the way forward.
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #21 of 29 Old 05-15-2010, 10:56 PM Thread Starter
Jcowart95
4x4 still not working. My shifting is not the problem anymore. I can shift into 4 wheel drive but tires dont turn. suggestions?
post #22 of 29 Old 05-16-2010, 01:54 AM
dtn8tr
All of them or just the front?
dtn8tr is offline
post #23 of 29 Old 05-16-2010, 01:56 AM
dtn8tr
Look on the passenger side of the engine compartment for the red vacuum line and make sure that it is hooked up to manifold vacuum. If it is then you need to make sure that the line from the t/c is hooked up.
dtn8tr is offline
post #24 of 29 Old 05-16-2010, 02:02 AM
littleredjeep
I would venture to say that you have a vacuum leak. You need to go to read the FAQ at the beginning of the YJ section. Go to the second post. Scroll down just a little bit and there is a write up on how your 4 wheel drive works. There is even a picture diagram with the colors and where they go for the vacuum. Good luck. Hope this helps.
88 YJ 4.2, 5-speed, 4"RC lift, 5/8 booms, herced tub, and cavi seats
My build thread
_____
/| ,[___],
|--L --[]lllll[]-
()_) ()_)-o-)_)
littleredjeep is offline
post #25 of 29 Old 05-16-2010, 02:03 AM Thread Starter
Jcowart95
the front tire wont turn. Where's the line from the t/c supposed fo go?
post #26 of 29 Old 05-16-2010, 11:05 AM Thread Starter
Jcowart95
What do yall think about this crap? when locked in 4wd, front drive shaft turns, but front wheels do not. I think i'm ready to sale this thing!
post #27 of 29 Old 05-16-2010, 11:44 AM
squib518
Until you check vacuum like has been stated on this thread several times and then read the info on the system as suggested by LittleredJeep, you will continue spinning your wheels--both figuratively and possibly/or not in reality.
squib518 is offline
post #28 of 29 Old 05-16-2010, 06:42 PM
dtn8tr
The red line from the tc goes to manifold vacuum! If this is not hooked up to manifold vacuum your front axel won't lock but the tc will go into 4wd! We've stated this, please follow what we tell you to look at because most everybody here has been through something similar, that's why we respond to the questions. I'm fairly new to Jeeps but I've been working on my own cars for almost thirty years. We are trying to help you out but you have to be willing to listen.
dtn8tr is offline
post #29 of 29 Old 05-16-2010, 06:59 PM
OnlynAYJ
Go to a junkyard and find the passenger side axle shaft out of something with a D30 and just remove all the vacuum disconnect stuff.
75% of the planet is covered by water. The rest is covered by Jeep
OnlynAYJ is offline
Brake Caliper Issue/brakes sticking issue Pottymouth TJ Wrangler Technical Forum 23 04-01-2013 10:07 PM
need help with steering issue and running to rich issue Dadseagleeyes TJ Wrangler Technical Forum 0 03-25-2010 08:17 PM
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 06:07 PM
BFG MT issue and OEM fog light issue AJasonK TJ Wrangler Technical Forum 12 09-14-2008 02:17 PM
Power steering pump issue and Alternator wiring issue... Help.... rustywrangler YJ Wrangler Technical Forum 22 01-05-2007 03:16 PM
