4x4 issue - JeepForum.com
post #1 of 29 Old 05-11-2010, 08:02 PM Thread Starter
Jcowart95
4x4 issue
I can not seem to engage 4 wheel drive. It will only go into neutral and 2 high. Whats the deal?
Jcowart95 is offline
post #2 of 29 Old 05-11-2010, 10:49 PM
MJMPC
How do you know you dont have 4x4?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #3 of 29 Old 05-12-2010, 12:38 AM Thread Starter
Jcowart95
Because i've attempted to put it in and it will not engage. I've pulled the shifter back as far as it will go and popped the clutch and only the back tires spin. it had worked fine untill i put a frame underneath it.
post #4 of 29 Old 05-12-2010, 03:48 AM
CSCmrwizard
1982 CJ5
do you have vac. on you front axel
Jeeps dont FLOAT!!!!!!
93 YJ
82 CJ5
CSCmrwizard is offline
post #5 of 29 Old 05-12-2010, 05:23 AM
ZeroGravity
Well the Transfercase pattern is 2HI-4HI-N-4LO, so if you can get it to shift into neutral than you should be able to shift it at least into 4HI.
Then again, I'm making that assumption because this is in the YJ tech and most YJs have the NP231, so you could have a different vehicle/T-case.
Fill out your profile.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline
post #6 of 29 Old 05-12-2010, 05:23 AM
squib518
What year is your Jeep? The Command Trak system on the front axle that runs the 4X4 changed over a little somewhere around 1990. It is usually a fairly simple fix.
First, to see if you have proper vacuum. Does the light on the dash (4X4) come on when you engage the four-wheel drive? If so, depending on your year model, that should mean you have at least some vacuum. Start there, and report back.
If you are feeling froggy, pull the vacuum harness off the Command Trak and feel for vacuum or better yet borrow a tester from Autozone. If you are getting proper vacuum, though, you should be able to feel the vacuum pull on the harness without a tester--just hold a finger over the holes. Be sure to cover the hole that runs to the vacuum line that controls the dash light or you will have introduced a leak---it just takes three hands ;-).
Be very careful testing the vacuum at the harness with the jeep idling---you don't have to put the jeep in gear. DON'T RUN OVER YOURSELF. Seriously.
Good luck.
squib518 is offline
post #7 of 29 Old 05-12-2010, 02:45 PM Thread Starter
Jcowart95
by the way this is my first jeep, i'm only 25. Now is that whats sitting on the passenger side of the axel? Please guys dont laugh but i'm pulling a Johnny Cash and doing one piece at a time.
post #8 of 29 Old 05-12-2010, 02:47 PM Thread Starter
Jcowart95
no my pattern is 4H 2H N 4L. I can only shift between 2H and N.
post #9 of 29 Old 05-12-2010, 03:09 PM
dtn8tr
How about a year for that jeep?
1997 TJ, 5" IRO front with 4.5" HD IRO WJ rear, 35x12.5x15 Mickey Thompson MTZ, JKS disconnects
dtn8tr is offline
post #10 of 29 Old 05-12-2010, 03:19 PM
squib518
So if you are saying that it won't even shift into those modes (the shifter itself won't budge), then I am not sure what your problem is. If you are saying that it doesn't work when you shift into those modes, I would check vacuum.
squib518 is offline
post #11 of 29 Old 05-12-2010, 03:29 PM Thread Starter
Jcowart95
the year is 1995
post #12 of 29 Old 05-12-2010, 03:39 PM
NateWithoutBeer
So can you physically shift to those positions or will the shifter not go that far? Have you checked underneath to make sure the linkage between the shifter and the transfer case isn't hitting anything or obstructed?
NateWithoutBeer is offline
post #13 of 29 Old 05-12-2010, 03:55 PM
dtn8tr
The rest of you correct me if I'm wrong...the '95 should still have the NP231J with a shift pattern of 2h-4hi-N-4lo starting from forward working back. You can shift the first two positions which should put it into 4hi. You have to physically move the shifter to the right and pull down to get it into N and then 4lo. I know when I picked mine up a couple of months ago it was a bear to get it to move to the right because it really hadn't been used for a number of years. If it is a matter of not shifting you can have a linkage bind or it could just be stiff like mine was. I recently replaced my carb with a Weber and disco'd a bunch of vacuum hoses and inadvertently moved the vac hose going the axle so when I went to use my 4wd the other day it didn't work. Put it up on jackstands and put it into gear to verify that the front wasn't locking and then tracked down the hose...all is well now. Locate the red vacuum line on the passenger side of the engine and make sure that it is hooked up to manifold vacuum and make sure that the line at the axle(yellow, I think) is hooked up. Follow it and make sure that it is not cracked or disconnected.
dtn8tr is offline
post #14 of 29 Old 05-12-2010, 05:17 PM
MJMPC
Remember your jeep has a Z gate you have to move the shifter to the right and down to get 4low.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #15 of 29 Old 05-12-2010, 05:41 PM
dtn8tr
I did a little more digging...that shift pattern is from the 80's CJ's. Either somebody replaced the knob because the old one fell off or you're running a Dana 300 t/c that somebody swapped in. I don't know the compatibility with a '95 engine but I'm sure somebody here can tell you what to look for other than physically checking the tag on the t/c to make sure which you have.
dtn8tr is offline
Brake Caliper Issue/brakes sticking issue Pottymouth TJ Wrangler Technical Forum 23 04-01-2013 09:07 PM
need help with steering issue and running to rich issue Dadseagleeyes TJ Wrangler Technical Forum 0 03-25-2010 07:17 PM
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
BFG MT issue and OEM fog light issue AJasonK TJ Wrangler Technical Forum 12 09-14-2008 01:17 PM
Power steering pump issue and Alternator wiring issue... Help.... rustywrangler YJ Wrangler Technical Forum 22 01-05-2007 02:16 PM
