4wheel drive light - JeepForum.com
post #1 of 2 Old 06-01-2013, 02:04 PM Thread Starter
jeeper95creeper
4wheel drive light
My 4x4 light stays on even when in 2wd.what's is causing this?I have a 92 yj
jeeper95creeper is offline
post #2 of 2 Old 06-01-2013, 02:42 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Could be a number of things.
Start with inspecting the CAD (central axle disconnect) system on the passenger side axle tube. Check to see if the vacuum connector is getting vacuum in both directions when you cycle the tcase shifter with the engine running. When in 2wd it should have vacuum one way - when in 4wd the other side should have constant vacuum.
If its not cycling from one hose tube to the other as the tcase shifter is being cycled w/engine running, trace the vacuum hose back to the tcase connector for problems.
If its not cycling due to a vacuum problem, this *could* cause the dash light not to extinguish.
Joe Dillard is offline
