4wheel drive indicator light on dashboard - JeepForum.com
post #1 of 15 Old 12-29-2011, 08:36 AM Thread Starter
rio jeep
Hey guys just have a quick question , when I put my jeep into 4wd my indicator light inside my jeep doesnt go on and last year it did does anyone have an idea of what may cause it not to go on? Thank You
rio jeep is offline
post #2 of 15 Old 12-29-2011, 09:02 AM
jbolty
jbolty's Avatar
bad bulb?
bad wire?
bad switch?
bad connection?
Just pull your jeep up to the computer and we'll take it from there.
jbolty is offline
post #3 of 15 Old 12-29-2011, 09:25 AM
scubamc
Originally Posted by jbolty View Post
bad bulb?
bad wire?
bad switch?
bad connection?
That pretty much sums it up.
check the vacuum lines. Are you sure it's going into 4wd?
scubamc is offline
post #4 of 15 Old 12-29-2011, 09:42 AM Thread Starter
rio jeep
Thanks for the info !!!! My jeep is definitely going into 4wd cause I can feel the difference in 4 low, my question is where is the switch located ????
rio jeep is offline
post #5 of 15 Old 12-29-2011, 09:48 AM
Siva283
It will be in 2 wheel low if the front axle is not engauging.Your gonna need a better test.
Siva283 is offline
post #6 of 15 Old 12-29-2011, 09:54 AM
jbolty
jbolty's Avatar
If you have the original vacuum disconnect assymbly for your year, the switch is part of the actuator.
jbolty is offline
post #7 of 15 Old 12-29-2011, 10:01 AM Thread Starter
rio jeep
I guess i have to get the truck in the air and make sure the front wheels turn...
rio jeep is offline
post #8 of 15 Old 12-29-2011, 12:29 PM
Siva283
Actually and I may be remembering this wrong I am sure someone will correct me if I am but an easier way to do it if you dont have a vehicle lift is to put it in 4wheel and put it in gear and then turn the engine off and jack up one side of the front. If it is in four wheel it should not turn. If it is not it four wheel it should turn. You should be able to turn it with your hands.
Ask me how I know...
Siva283 is offline
post #9 of 15 Old 12-29-2011, 12:34 PM Thread Starter
rio jeep
Ok thanks Im going to give it a try in a little
rio jeep is offline
post #10 of 15 Old 12-30-2011, 02:03 PM Thread Starter
rio jeep
So I jacked up the front wheels while it was in 4wd and both wheels spin freely and also I checked for vacuum and my vacuum is good going to the vacuum pump so im trying to think maybe its the pump... Does anyone have any other suggestions thanks guys !!!!!
rio jeep is offline
post #11 of 15 Old 12-30-2011, 03:14 PM
Mark05059
You need a second person... you need to pull the line off of the actuator (there are 2 separate lines that plug in) find the vac one one line and have the other person put the jeep in and out of 4x. The vac should switch from one line to the other... if it does then your actuator is junk. If it doesnt then you need to check out the switch at the transfer case.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #12 of 15 Old 12-30-2011, 03:18 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
First make sure your driveshaft doesn't spin free in the aforementioned 4wd test. Then do this:
Luck Favours The Prepared
Anticanman is offline
post #13 of 15 Old 12-30-2011, 07:35 PM
Siva283
When you spun the tire did the drive shaft spin? It should have. You specifically wanna spin the passenger side front since that's the side the cad dissconnects. Also what's it feel like when you move the swifter to 4 wheel
Siva283 is offline
post #14 of 15 Old 01-03-2012, 05:04 AM Thread Starter
rio jeep
I will check the vacuum today and make sure it switches from one side to another when engaged in 4wd and make sure the driveshaft is spinning... all in all it goes in smooth from 2wd to 4wd so I know theres no issues there.. Thanks for the help and HAPPY NEW YEAR !!!!!!!
rio jeep is offline
post #15 of 15 Old 01-04-2012, 05:04 PM
hfa8592
Follow this link too, a lot of helpful info about the 4x4 shift motor and vac system. I had this problem in my '93 YJ when I bought it and just replaced all the vac hoses with new ones. Also, discarded the plug on top of the NP231 and just plugged all four hoses directly into the nozzles on the t-case. This completely solved my problem.
http://www.jeepforum.com/forum/f12/v...-motor-965484/
Scott
'93 YJ, 4" spring lift, 4.0 I6, NV4500, Atlas II, SYE, Currie/Ford 9" rear axle, ARBs front & rear, Kilby OBA, 33" Wrangler MTRs, custom cage, custom bumpers.
hfa8592 is offline
Dashboard indicator lights gerryjeep TJ Wrangler Technical Forum 0 08-09-2011 08:45 PM
Four Wheel Drive Indicator Light Living_High YJ Wrangler Technical Forum 19 05-25-2010 08:53 PM
4-wheel drive indicator light? Where is it? china-clipper YJ Wrangler Technical Forum 17 03-08-2009 08:26 PM
4wheel drive light cp10goat71 TJ Wrangler Technical Forum 8 02-28-2007 04:33 PM
4 wheel drive indicator light moabster YJ Wrangler Technical Forum 4 05-07-2002 06:20 PM
