4wd wont stay in - JeepForum.com
post #1 of 1 Old 04-03-2010, 06:29 AM Thread Starter
newjeeper369
4wd wont stay in
this winter my 4wd started to slip out when im using it, so i put a posi lock on it thinkin it was the vacuum but when i pulled the vacuum motor off i turned the 4wd on and the vacuum seems fine its strong enough to push my hand with the fork. so i put the posi lock on anyway. it worked ok for like a day or so but now when i try it, it doesnt wanna go in at all or if it does, it seems to fall out when i turn. im thinkin its the gear that the fork moves is stripped or i have a bad bearing so my shaft is crooked so the gear cant slide on all the way on.
newjeeper369 is offline
Wont stay in low 4x4 arni TJ Wrangler Technical Forum 14 03-14-2010 09:58 AM
TBI 4.2L wont stay running jaminb YJ Wrangler Technical Forum 0 11-10-2009 08:40 AM
TJ Wont Stay Running. Jlamping TJ Wrangler Technical Forum 2 12-17-2007 03:07 PM
T-Case wont stay in 4-low TnTRacing28 YJ Wrangler Technical Forum 2 04-09-2007 11:50 AM
Wont stay in 4X4HI OR LO Jcpierc21 TJ Wrangler Technical Forum 2 02-05-2005 08:45 PM
