Quantcast 4wd wont engage - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > 4wd wont engage
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 12-23-2004, 07:13 PM   #1
RAYMAN975
4wd wont engage
RAYMAN975 is offline   Reply With Quote
Old 12-23-2004, 08:30 PM   #2
lordmatt
If it goes into 4wd (while rolling @ 5mph or less)... then what's the problem? Your 4wd is still working...
'91 YJ - Flat Black
35x12.50x15 BFG Mud-Terrain TA's on 15x8 Black Rockcrawlers
SOA, SYE
Cut fenders
Recessed tails
Herc's interior
Fabbed front bumper
misc fun stuff
lordmatt is offline   Reply With Quote
Old 12-23-2004, 09:43 PM   #3
Truth
Are you really trying to shift the T-case while going 30 mph? It is NOT a shift on the fly case. And it's not a transmission with a clutch. You should be STOPPED while shifting the Tcase, or crawling very slowly, and not be in 4lo on pavement.
Are you trying to break your vehicle? It sure sounds like it.
Truth is offline   Reply With Quote
Old 12-23-2004, 10:05 PM   #4
saminwy
http://www.jeepforum.com/forum/f12/why-cant-i-engage-4x4-motion-67904/
this thread might give you some idea of whats going on.
and yes, yj's are supposed to shift on the fly from 2 hi to 4 hi. should glide right in at highway speeds(of course this should not be doen on dry pavement)
saminwy is offline   Reply With Quote
Old 12-24-2004, 01:49 PM   #5
RAYMAN975
Old 12-24-2004, 02:06 PM   #6
CosmicCreeper
What's the owners manual say?
USN Jeep Club Hull #1
CosmicCreeper is offline   Reply With Quote
Old 12-25-2004, 12:11 PM   #7
RAYMAN975
Old 12-28-2004, 12:38 PM   #8
Tshark299
1987 YJ Wrangler
Mine wont shift on the fly if I havent used it in a while. The first time this season it was impossible to get mine to shift. Since it's been snowing regularly since then though, it's gotten alot better. I remember the same thing happening to me last winter too. By the end of the season it would slide in and out of 4HI easily.
'87 YJ Laredo - 4.0L, AX-15, NP231, 4.10s: 3.5" BDS, 31" Muds
'95 XJ - Donated drive train to the YJ, Parting the rest out
'51 CJ-3A - Buick 225 V6: Painless Wiring Harness, Warn Overdrive & Hubs, 2" Lift, 31" Muds
Tshark299 is offline   Reply With Quote
Old 12-28-2004, 06:17 PM   #9
RAYMAN975
Old 12-29-2004, 11:01 AM   #10
Tshark299
1987 YJ Wrangler
I think the whole 8 years of no use is the reason it's so tough to shift right now. I'm sure it will shift on the fly better the more you use it. You just might have to muscle it in at first sometimes.
Old 12-29-2004, 09:55 PM   #11
RAYMAN975
Old 12-30-2004, 09:27 AM   #12
Tshark299
1987 YJ Wrangler
Well, it's hard to tell without actually knowing first hand exactly how stuck your shifter is and how strong your arm is, but I can tell you that I've never had any bent fork problems with mine, not that I know of at least
Glock Forum
