4wd vacuum question - JeepForum.com
post #1 of 3 Old 04-26-2012, 12:29 PM Thread Starter
bluedaffy
4wd vacuum question
1989:4.2L:nuttered:weber 32/36
After nuttering my jeep, installing a weber carb and taking off the 3 vacuum solenoids I was left with a vacuum line for the 4wd that T's twice. I'm not sure why it is, maybe it was hooked into the 3 vacuum solenoids that I got rid of when I pulled the computer from the loop. In any case, can I get rid of the T's in the line to make it one straight vacuum line and hook into manifold? If not, maybe someone could help me with where the 4wd vacuum line(s) go.
bluedaffy is offline
post #2 of 3 Old 04-26-2012, 01:58 PM
dancytron
You'll see a red line with a checkvalve at the end. That is the vacuum source for the 4wd. You can clean up whatever leftovers there are as long as you have that is hooked up to manifold vacuum.
If it is temperamental, it is probably easier in the long run to replace all the vacuum lines you have left instead of trying to find leaks and repair individual sections.
dancytron is offline
post #3 of 3 Old 04-26-2012, 02:24 PM Thread Starter
bluedaffy
Thanks much
4wd , vacuum
Vacuum Question Mark-n-Jane TJ Wrangler Technical Forum 9 03-24-2011 12:50 PM
Vacuum Question denalione YJ Wrangler Technical Forum 2 03-27-2009 08:07 PM
4WD Vacuum Question CheapSunglasses YJ Wrangler Technical Forum 6 12-08-2008 06:20 PM
np-231 vacuum question krd YJ Wrangler Technical Forum 4 05-13-2008 05:28 PM
Vacuum Question Loopmd YJ Wrangler Technical Forum 11 11-17-2004 10:45 PM
