4WD vacuum lines - JeepForum.com
post #1 of 4 Old 01-19-2002, 02:52 PM Thread Starter
glm 87 wrangler
4WD vacuum lines
Has any one changed vacuum lines going to the 4wd system? Is it hard and do they sale the vacuum lines in the size made for it aready?
Any input on this would be great.Later,gary
Gary 87 Wrangler 4.2 258 with weber carb and TFI upgrade.
31/10.5 and Nutter bypass!
glm 87 wrangler is offline
post #2 of 4 Old 01-20-2002, 04:10 PM
Corky
the whole vacuum harness is available from Jeep (Chrysler) for about $45. It takes about 15 minutes to install!
1990 2.5 jeep wrangler
Corky is offline
post #3 of 4 Old 01-20-2002, 06:26 PM
mc87yj
I just got done repairing mine.I used some pneumatic tubing used in the a/c controls business.I believe it is 3/16".I spliced in with male to male barb fittings.I had to heat up[lighter]the jeep ends a little to get barb to go in.Works perfect.If you need some tubing,fittings go to a good air conditioning supply house or e-mail me and I could send you some.You might try a place like Graingers also.I'm going to lock my front end in permanent as soon as it warms up.
mc87yj is offline
post #4 of 4 Old 01-21-2002, 06:46 AM Thread Starter
glm 87 wrangler
thanks Guys for the info.
Necessary Vacuum lines? YJ800 YJ Wrangler Technical Forum 1 07-17-2009 11:18 PM
Vacuum Lines SEMO 95 YJ YJ Wrangler Technical Forum 2 03-01-2008 06:26 PM
which vacuum lines can i get rid of? FASTMETAL YJ Wrangler Technical Forum 1 09-27-2007 04:25 PM
Vacuum Lines mxracer513 YJ Wrangler Technical Forum 3 08-09-2007 08:37 PM
Vacuum Lines 87 yj 2.5L Boog44 YJ Wrangler Technical Forum 8 12-16-2006 01:07 PM
