4WD vac system - JeepForum.com
post #1 of 4 Old 01-25-2009, 05:05 PM Thread Starter
sjwrangler
4WD vac system
For now I've decided to keep the vac system for my 92 Wrangler. I ordered new vac hose assembly from the dealer and new vac motor on line.
How difficult is it to change out? Particularly, how about the connections on the trans case? Are those crimped or pressed on?
What other parts might need to be changed. I want to be prepared. Its too cold right now to enjoy this type of work on the YJ.
Thanks
His: 92 YJ 2.5, true-track front/&rear, Meyers plow
Hers: 04 Columbia Edition. 6 cyl., 4" lift, 35s
sjwrangler is offline
post #2 of 4 Old 01-25-2009, 06:36 PM
kloppk
The hose cluster simply presses onto the vacuum switch on the tcase.
No clamps or anything.
I'd recommend you also replace the tcase vacuum switch as long as
you are replacing most everything else. The vacuum switches are fairly failure prone.
The switch simply screws into the tcase and is only about $15.
It's a fairly simple job to do. The hardest part is getting to the vacuum switch on the tcase.
Not much room to get in there with the skid plate, shift linkage and DS in the way.
kloppk is offline
post #3 of 4 Old 01-26-2009, 05:05 AM Thread Starter
sjwrangler
Can you see it from the top? My boot is loose right now.
post #4 of 4 Old 01-26-2009, 06:21 AM
muddy93
1987 FSJ Wagoneer
yes you can!
that's how I got to mine when I had to work on my 4x4 vac system. you'll have to remove the boot, as well as the plate under it.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
vacuum system hoses all hooked up but system doesnt work snowcrawlr619 YJ Wrangler Technical Forum 8 12-28-2009 07:52 AM
Getting Rid of A/C System tgrout YJ Wrangler Technical Forum 6 03-11-2009 12:59 PM
In a rut with my HID system wvangel87 TJ Wrangler Technical Forum 4 06-30-2008 05:02 AM
OBA system 03Wrangler YJ Wrangler Technical Forum 8 02-23-2007 12:12 AM
PA system AK1904 YJ Wrangler Technical Forum 1 12-29-2003 04:06 PM
