4WD vac leak? engine related? - JeepForum.com
post #1 of 4 Old 07-19-2008, 06:25 AM Thread Starter
YJames90
YJames90's Avatar
I was just reading an article on switching out YJ shafts for TJ shafts. It mentioned plugging the vac lines. When I installed the posi-lok I just cut the vac lines and did not pulg them. Is the 4wd vac unit seperate from the engine vac unit or does it all work off the engine? Should I plug theses lines for better enginr performance?
My 2.5 to 4.3 swap thread
YJames90 is offline
post #2 of 4 Old 07-19-2008, 06:35 AM
NJeepyj91
I have the posi lok and I plugged them. I just figured since they "suck" I didn't want anything getting in.
She's going to bury me in this thing.
91 4.0 stick. Posi Lok, Borla, 31s on steelies, Dem Bonz Shackles and lots of other junk on my junk.
NJeepyj91 is offline
post #3 of 4 Old 07-19-2008, 10:23 AM
crusty75
1975 CJ5
Yes, plug them. You may have to re-tune your engine. Vac leaks will cause a lean condition...
But what do I know? I'm old.
crusty75 is offline
post #4 of 4 Old 07-19-2008, 10:40 AM Thread Starter
YJames90
YJames90's Avatar
So the vac is created from the engine, that makes sense . Thanks
YJames90 is offline
Exhaust leak. Any related issues? YJake YJ Wrangler Technical Forum 0 08-27-2009 06:44 PM
Replaced starter but still won't turn over...leak from b/t tranny and TC...related? GDM97TJ TJ Wrangler Technical Forum 34 08-16-2008 08:45 PM
Some vent that might be related to rear main seal leak? TheMightyGoat TJ Wrangler Technical Forum 11 05-13-2008 07:57 PM
Engine ping - related to underhood air temp? JustPassinThru YJ Wrangler Technical Forum 3 09-06-2004 10:46 PM
Transmission Related (interior leak) bigjeep39 YJ Wrangler Technical Forum 2 10-24-2001 05:49 PM
