4wd.,. stuck in gear - JeepForum.com
post #1 of 4 Old 01-23-2002, 10:01 AM Thread Starter
bighair
hey guy's ,
I'm having a little issue.. I went and played in the snow the other day, it was deep and fun, but since then I can't seem to get out of 4 low.. when the stick is in position for 4 high the Jeep drives in 4 low and when the stick is in 2wd the Jeep drives in 4 high.. Any suggestions??
I've been trying to get it out of gear by trying to back and pop it out of gear. idling at slow, slow, slow, slow speeds and trying to pop it out of gear.. nothing
I'm going to lift it tongiht look at the vaccum pump maybe the tub to disengage is off or busted?? I'm going to check it out..
any other suggestions? other then going direct cable lock. hehe which I will be doing eventually, but don't have the means to right now. I need to get his done asap cause it's my only vehicle right now andI don't want to drive on bare pave with it in 4wd.. and ruine my gears..
Thanks
Team Mod Squad
We are here to help YOU!
bighair is offline
post #2 of 4 Old 01-23-2002, 05:38 PM
Bob K
Bob K's Avatar
Sounds like you need to adjust the 4WD shifter. It sounds like it's not able to pull far enough forward to disengage out of 4 wheel hi. If you don't have info on adjusting I'll scan and send you from Chilton's.
'87 Wrangler YJ 4.2 I6 (sorry, sold)
JuiceBox ignition
2 1/2" ProComp Lift
31" BFG A/T's
K&N Filter
Custom Rock Guards
Turbo Muffler
Rear Track Bar in the shed
Other Tricks I won't tell to just anybody!
'99 Grand Cherokee 4.7 V8
Towing Package
K&N FIPK
ProComp MX6 shocks
Borla Exhaust
Tow Hooks
Alpine CD with Infinity+iPod connect
Just getting started!
If you're not living on the edge...
you're taking up too much space.
Bob K is offline
post #3 of 4 Old 01-23-2002, 05:46 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Also check the linkage between the shifter and the T-case, sounds like something is slightly out of adjustment. You might have some snow in there .. find a heat gun and try to melt the moisture out.
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
post #4 of 4 Old 01-24-2002, 07:36 AM Thread Starter
bighair
Thanks for the help guys.. I'll take a look and see what I can' find.. I don't have a garage so it's kinda hard working onthe Jeep and ngiht in the cold with barely any light.. hehe I'm of on Friday so I'm going to fix it then and I'lll let you know what the problem was..
Thanks again
Team Mod Squad
bighair is offline
93 YJ 4.0L 4wd - Stuck in 4th Gear!! snacks99 YJ Wrangler Technical Forum 1 08-21-2009 08:46 AM
Stuck in Gear Pferg1984 YJ Wrangler Technical Forum 1 07-04-2006 02:50 PM
Stuck in 4th Gear!!!! Help!!! Junker 91 YJ YJ Wrangler Technical Forum 1 08-01-2005 09:21 AM
Help Stuck In 4th Gear Sahara2001 TJ Wrangler Technical Forum 6 02-27-2003 11:45 PM
ever get stuck in gear? reevesse YJ Wrangler Technical Forum 1 02-03-2003 03:04 PM
